AuKing M8-F Lens Replacement
  1. AuKing M8-F Lens Replacement, Lens: step 1, image 1 of 2 AuKing M8-F Lens Replacement, Lens: step 1, image 2 of 2
    • Make sure that the device is unplugged from any power source before attempting any repairs.
    • Flip the projector on its opposite side.
    • Remove all six of the 11 mm screws using a Phillips #1 screwdriver.
    • Remove the two 14 mm screws using a Phillips #1 screwdriver on the base of the projector
    Ask FixBot
  2. AuKing M8-F Lens Replacement: step 2, image 1 of 3 AuKing M8-F Lens Replacement: step 2, image 2 of 3 AuKing M8-F Lens Replacement: step 2, image 3 of 3
    • Carefully prop open the top of the projector.
    • Remove the cable attached to the top lid.
    • Remove the top lid.
    Ask FixBot
  3. AuKing M8-F Lens Replacement: step 3, image 1 of 2 AuKing M8-F Lens Replacement: step 3, image 2 of 2
    • Remove all four of the the 9 mm screws using a Phillips #1 screwdriver.
    Ask FixBot
  4. AuKing M8-F Lens Replacement: step 4, image 1 of 3 AuKing M8-F Lens Replacement: step 4, image 2 of 3 AuKing M8-F Lens Replacement: step 4, image 3 of 3
    • Flip up the black locking flaps then unplug the ribbon cable.
    • Disconnect the other wires connected to the motherboard.
    • Remove black panel.
    Ask FixBot
  5. AuKing M8-F Lens Replacement: step 5, image 1 of 2 AuKing M8-F Lens Replacement: step 5, image 2 of 2
    • Using both hands, hold the lens' holder and turn the lens counterclockwise to remove.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 95
All Time: 1,906
