AuKing M8-F Fan Replacement
  1. AuKing M8-F Fan Replacement, Motherboard: step 1, image 1 of 2 AuKing M8-F Fan Replacement, Motherboard: step 1, image 2 of 2
    • Make sure that the device is unplugged from any power source before attempting any repairs.
    • Flip the projector on its opposite side.
    • Remove all six of the 11 mm screws on the base of the projector using a Phillips #1 screwdriver.
    • Remove the two 14 mm screws using a Phillips #1 screwdriver.
    Ask FixBot
  2. AuKing M8-F Fan Replacement: step 2, image 1 of 3 AuKing M8-F Fan Replacement: step 2, image 2 of 3 AuKing M8-F Fan Replacement: step 2, image 3 of 3
    • Carefully prop open the top of the projector.
    • To remove the cord that is attached to the top, carefully wiggle the cord out.
    • Remove the top lid.
    Ask FixBot
  3. AuKing M8-F Fan Replacement: step 3, image 1 of 3 AuKing M8-F Fan Replacement: step 3, image 2 of 3 AuKing M8-F Fan Replacement: step 3, image 3 of 3
    • Flip up the black locking flaps then remove the two ribbon cables.
    Ask FixBot
  4. AuKing M8-F Fan Replacement: step 4, image 1 of 2 AuKing M8-F Fan Replacement: step 4, image 2 of 2
    • Remove the two 9 mm screws using the Phillips #00 screwdriver.
    Ask FixBot
  5. AuKing M8-F Fan Replacement: step 5, image 1 of 2 AuKing M8-F Fan Replacement: step 5, image 2 of 2
    • Carefully disconnect the wires that are attached to the motherboard.
    • Remove the motherboard.
    Ask FixBot
  6. AuKing M8-F Fan Replacement, Fan: step 6, image 1 of 2 AuKing M8-F Fan Replacement, Fan: step 6, image 2 of 2
    • Remove the two 9 mm screws using a Phillips #0 screwdriver to detach the small black panel.
    Ask FixBot
  7. AuKing M8-F Fan Replacement: step 7, image 1 of 2 AuKing M8-F Fan Replacement: step 7, image 2 of 2
    • Carefully pull out the fans from the projector.
    Ask FixBot
Aubrey Haynes
286 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 10
Past 30 Days: 33
All Time: 592
