AuKing M8-F Bulb Replacement
    1. AuKing M8-F Bulb Replacement, Motherboard: step 1, image 1 of 2 AuKing M8-F Bulb Replacement, Motherboard: step 1, image 2 of 2
      • Make sure that the device is unplugged from any power source before attempting any repairs.
      • Flip the projector on its opposite side.
      • Remove all six of the 11 mm screws on the base of the projector using a Phillips #1 screwdriver.
      • Remove the two 14 mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    2. AuKing M8-F Bulb Replacement: step 2, image 1 of 3 AuKing M8-F Bulb Replacement: step 2, image 2 of 3 AuKing M8-F Bulb Replacement: step 2, image 3 of 3
      • Carefully prop open the top of the projector.
      • To remove the cord that is attached to the top, carefully wiggle the cord out.
      • Remove the top lid.
      Ask FixBot
    3. AuKing M8-F Bulb Replacement: step 3, image 1 of 3 AuKing M8-F Bulb Replacement: step 3, image 2 of 3 AuKing M8-F Bulb Replacement: step 3, image 3 of 3
      • Flip up the black locking flaps then remove the two ribbon cables.
      Ask FixBot
    4. AuKing M8-F Bulb Replacement: step 4, image 1 of 2 AuKing M8-F Bulb Replacement: step 4, image 2 of 2
      • Remove the two 9 mm screws using the Phillips #00 screwdriver.
      Ask FixBot
    5. AuKing M8-F Bulb Replacement: step 5, image 1 of 2 AuKing M8-F Bulb Replacement: step 5, image 2 of 2
      • Carefully disconnect the wires that are attached to the motherboard.
      • Remove the motherboard.
      Ask FixBot
    1. AuKing M8-F Bulb Replacement, Bulb: step 6, image 1 of 2 AuKing M8-F Bulb Replacement, Bulb: step 6, image 2 of 2
      • Remove the six 9 mm screws using a Phillips #0 screwdriver to detach both of the black panels.
      Ask FixBot
    2. AuKing M8-F Bulb Replacement: step 7, image 1 of 3 AuKing M8-F Bulb Replacement: step 7, image 2 of 3 AuKing M8-F Bulb Replacement: step 7, image 3 of 3
      • Slide the motherboard upwards to remove the wire component connected to the LED bulb.
      • Gently remove the LED bulb and the attached heatsink from the projector
      Ask FixBot
Aubrey Haynes
286 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 38
All Time: 2,044
