Up to 20% off select tools
Atmega328P Microcontroller Replacement for Arduino Board
Views: 1.8K
View statistics:
Past 24 Hours:
Past 7 Days:
25
Past 30 Days:
108
All Time:
1,833
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Parts
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This is a guide on how to replace a ATMega328P microcontroller (Code: X000048) on an Arduino UNO R3 Board (Model: EL-CB-001, Code: A000066). This guide does not require any specialized skills or knowledge.
The ATMega328P processes the instructions in C from the Arduino IDE. If damaged, the code cannot be executed. Fortunately, replacing the microcontroller is a simple and uncomplicated process. Before starting the repair, please unplug the the Arduino board from the USB.
    1. Atmega328P Microcontroller Replacement for Arduino Board, Atmega328P Microcontroller: step 1, image 1 of 1
      • Place the Arduino UNO R3 board on a flat clean surface.
      Ask FixBot
    2. Atmega328P Microcontroller Replacement for Arduino Board: step 2, image 1 of 2 Atmega328P Microcontroller Replacement for Arduino Board: step 2, image 2 of 2
      • On the right side of board, position a nylon spudger in between the microcontroller and the dip socket, and gently lift upwards to pry it out.
      • The bottom of the microcontroller can be scratched if not done carefully. Do not use a metal tool for this step.
      Ask FixBot
    3. Atmega328P Microcontroller Replacement for Arduino Board: step 3, image 1 of 2 Atmega328P Microcontroller Replacement for Arduino Board: step 3, image 2 of 2
      • Repeat the same process on the other side.
      • Lift both sides evenly to prevent any damage to the pins.
      Ask FixBot
    4. Atmega328P Microcontroller Replacement for Arduino Board: step 4, image 1 of 3 Atmega328P Microcontroller Replacement for Arduino Board: step 4, image 2 of 3 Atmega328P Microcontroller Replacement for Arduino Board: step 4, image 3 of 3
      • Repeat steps 2 and 3 until the microcontroller is loose enough to remove out of the socket.
      Ask FixBot
    5. Atmega328P Microcontroller Replacement for Arduino Board: step 5, image 1 of 1
      • Remove replacement microcontroller out of packaging.
      Ask FixBot
    6. Atmega328P Microcontroller Replacement for Arduino Board: step 6, image 1 of 1
      • If needed, straighten the pins of the replacement microcontroller and place it directly over the dip socket.
      • Make sure the notch on the side of the microcontroller is facing the right, matching the white lines on the board.
      Ask FixBot
    7. Atmega328P Microcontroller Replacement for Arduino Board: step 7, image 1 of 2 Atmega328P Microcontroller Replacement for Arduino Board: step 7, image 2 of 2
      • Gently press the microcontroller into the dip socket
      Ask FixBot
3 other people completed this guide.
Author
with
Youssef Qteshat
217 Reputation
1 Guide authored
UC Davis, Team 5-5, Morris Winter 2023 Member of UC Davis, Team 5-5, Morris Winter 2023
UCD-MORRIS-W23S5G5
2 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 108
All Time: 1,833
