Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓This repair is for an Atari Flashback 6 controller. Over time, controller wiring can wear down and disconnect from the terminals. In this guide, we will demonstrate how to disassemble, re-solder the wires to the terminal, and then reassemble your Atari Flashback 6 controller. You can achieve all nine steps with little to no experience, as long as you have the right tools. Handle tools such as a soldering iron and exacto knife with care to prevent injury or controller damage.
Information on how to solder
Before you begin the repair, make sure to remove the batteries from the controller.
Tools
Spudger4.9
Use a Phillips #1 screwdriver to remove single 1.5 mm-long screw securing the battery cover.
Lift the battery cover off.
Depress the spring that is in contact with the negative side of the battery to remove the batteries. Push down, and then remove batteries one at a time.
Ensure you test your controller when finished to verify the proper connection.
