Atari 2600 Jr. Rev. A Disassembly
  1. Atari 2600 Jr. Rev. A Disassembly, Remove the base: step 1, image 1 of 1
    • Remove 5 Phillips screws from base.
  2. Atari 2600 Jr. Rev. A Disassembly, Detach the Case: step 2, image 1 of 3 Atari 2600 Jr. Rev. A Disassembly, Detach the Case: step 2, image 2 of 3 Atari 2600 Jr. Rev. A Disassembly, Detach the Case: step 2, image 3 of 3
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
    • Use a metal or heavy duty spudger to unhook the 3 plastic clips holding the front of the case together.
    • Be careful not to break the plastic clips
    • While unhooking the center hook use another spudger to run along the top and bottom casing. This helps to get the clip lose.
    • Be careful not to pull the case apart quickly, there is a ribbon that is attached to the top and bottom.
  3. Atari 2600 Jr. Rev. A Disassembly, Detach the Ribbon: step 3, image 1 of 1
    • Detach the ribbon from the circuit board by gently pulling ribbon out from clip.
  4. Atari 2600 Jr. Rev. A Disassembly, Remove Circuit Board from Base: step 4, image 1 of 2 Atari 2600 Jr. Rev. A Disassembly, Remove Circuit Board from Base: step 4, image 2 of 2
    • There are 2 clips holding the circuit board in place.
    • Using a metal or heavy duty spudger release the clip on the left side.
    • Remove the circuit board.
Finish Line
9 other people completed this guide.
Aislinn
345 Reputation
1 Guide authored
1 Guide Comment
Great process for dis-assembly. Now all I need is a replacement reed switch as mine is broken. Being in Australia it is very hard to find one locally. many Thanks.
Singoau - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 68
All Time: 5,567
