Introduction
Go to step 1 βReplace your screen to restore your Asus Zenfone 4 Max phone screen's capabilities or appearance
Tools
Using a removable head screwdriver and a T3 bit, begin by removing the two screws located on either side of the charging port.
Using a removable head screwdriver and a T4 bit, remove the screws on the base of the phone on either side of the charging port.
Starting near either of the 4 corners of the device notice the seam of the case around the front of the device.
Begin using the opening tool with a moderate amount of force to wedge between the back case and the phone.
Gently move the tool around the edges towards each corner until the back is removed.
Using the screwdriver with the PH0 bit, unscrew all screws found on the circuit board.
4 other people completed this guide.
3 Guide Comments
in one step it says use a T3 for to the left and right of the charging port, later it says T4. also, the guide has what i believe to be a typo, as it mentions an βAT3β bit for removal of the internal bottom panel. just wanted to alert you to these inconsistencies. overall seems to be a good guide, i shall be replacing my screen soon as i have cracked the corner and find it unsightly. thank you, have a nice evening.
This was a fun fix, usually I fix iPad or iPhone, so this was my first time fixing an Asus and was easier than I thought it was gonna be. Just take your time as I didn't now I'm fixing something else .
I need asus zenfone lcd and battery
