Asus Zenfone 4 Max Camera Replacement
    1. Asus Zenfone 4 Max Camera Replacement, Camera: step 1, image 1 of 1
      • Using a removable head screwdriver and a T4 bit, remove the screws on the base of the phone on either side of the charging port.
      Ask FixBot
    2. Asus Zenfone 4 Max Camera Replacement: step 2, image 1 of 1
      • Starting near either of the 4 corners of the device notice the seam of the case around the front of the device.
      • Begin using the opening tool with a moderate amount of force to wedge between the back case and the phone.
      • Gently move the tool around the edges towards each corner until the back is removed.
      • You will be able to hear the back casing pulling apart from the phone. Do not be alarmed, but work gently with the device.
      Ask FixBot
    3. Asus Zenfone 4 Max Camera Replacement: step 3, image 1 of 2 Asus Zenfone 4 Max Camera Replacement: step 3, image 2 of 2
      • Using a removable head screwdriver and a PH0 bit, begin removing the panel beneath the two cameras by unscrewing the screw.
      Ask FixBot
    4. Asus Zenfone 4 Max Camera Replacement: step 4, image 1 of 3 Asus Zenfone 4 Max Camera Replacement: step 4, image 2 of 3 Asus Zenfone 4 Max Camera Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Use the tweezers to gently pull up on the flaps beneath the two cameras.
      • Completely remove the cameras and replace with the new cameras.
      Ask FixBot
Maegan West
839 Reputation
4 Guides authored
2 Guide Comments
You can read T3 in the summary and T4 in the instructions: which one do I need?
patriziomaugeri - Reply Share
Does this fix the Zenfone 4 max camera black screen?
Roger Dufault - Reply Share
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 64
All Time: 2,502
