Introduction
If your Asus Zenfone 4 Max phone fails to charge, it could be due to a malfunctioning battery. This guide will help you remove your phone battery and replace it with a new one. Replacing the battery must be done with great care.
Using a removable head screwdriver and a T3 bit, begin by removing the two screws located on either side of the charging port.
4 other people completed this guide.
5 Guide Comments
My FPC connector is broken as well as female battery connector, are these worth the time and money to replace or are new motherboards available?
Off topic: But anyone have success removing glass without damaging digitizer without any specialized tools on a xooid I have two 4max pro i have a new glass only:/uv glue / two back case, home buttons,2 replacement earpiece speakers, two sim trays, one rose gold and white one black on black, both useless now. Any advice of sourcing parts, or try to seperate glass, desolder and replace battery connectors or just scrap it all?
A few more screws then mentioned - one at bottom and one at top to release battery connector. Go slow!
I had to use a Torque 2 for the first two at the charging jack NOT Torque 3. The rest are small Phillips.
You certainly need the prior bars to get the back off the first time as it ‘stuck’ - so is the battery.
IMPORTANT - take the slide with the memory and phone chip out before starting. Just go slow and careful.
Trop vieux pour que je change la batterie surtout si c'est pour tomber sur un rebus hors d'âge, hop recyclage de ce smartphone qui m'aura rendu de bons services mais qui ramait depuis quelques mois déjà. J'attendais juste un bon prétexte pour changer. Enfin pour la panne c'est la nappe d'alimentation de la batterie qui est coupé au milieu je sais pas pourquoi... (peut être les chutes multiples). Mais à 150€ pour 4 ans et 7 mois d'utilisation je trouve que c'est largement amorti et qu'il est grand temps de changer de modèle.
A few more screws needed in step 3 (it was actually 6 in total) then I was able to remove the bottom panel, I did that as a test since for me it had not been necessary to remove that panel in order to remove the battery. Removing the bottom panel exposes more delicate parts to possible damage so just leave it in place. Be careful when prying up the battery and go very slow. Do not puncture the battery only use flat strong spudgers and do not go too much in because at the bottom of the battery there's a flat cable which you might cut or damage if the spudger goes in too much. With the panel in place I was able to remove the battery and place a new one. The only issue is that I get a phone with a blinking red led at the top left of the screen edge and the phone won't start.
