Asus Zenbook UX32VD GPU Fan Replacement
    1. Asus Zenbook UX32VD GPU Fan Replacement, Bottom Panel: step 1, image 1 of 3 Asus Zenbook UX32VD GPU Fan Replacement, Bottom Panel: step 1, image 2 of 3 Asus Zenbook UX32VD GPU Fan Replacement, Bottom Panel: step 1, image 3 of 3
      Tool used on this step:
      T5 Torx Screwdriver
      $9.99
      Buy
      Ask FixBot
    2. Asus Zenbook UX32VD GPU Fan Replacement: step 2, image 1 of 3 Asus Zenbook UX32VD GPU Fan Replacement: step 2, image 2 of 3 Asus Zenbook UX32VD GPU Fan Replacement: step 2, image 3 of 3
      • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
      • Remove the bottom panel from the body of the laptop.
      • Set aside the bottom panel.
      Ask FixBot
    1. Asus Zenbook UX32VD GPU Fan Replacement, Fan: step 3, image 1 of 3 Asus Zenbook UX32VD GPU Fan Replacement, Fan: step 3, image 2 of 3 Asus Zenbook UX32VD GPU Fan Replacement, Fan: step 3, image 3 of 3
      Spudger
      $2.99
      Buy
      • Use the tip of your spudger or your fingernail to open the ZIF connector on the I/O board.
      • Be sure to pry up on the hinged retaining flap, not the connector itself.
      • Remove the metallic ribbon cable from the connector .
      • No force is needed to remove or insert the cable.
      Ask FixBot
    2. Asus Zenbook UX32VD GPU Fan Replacement: step 4, image 1 of 3 Asus Zenbook UX32VD GPU Fan Replacement: step 4, image 2 of 3 Asus Zenbook UX32VD GPU Fan Replacement: step 4, image 3 of 3
      Phillips #0 Screwdriver
      $5.49
      Buy
      Ask FixBot
    3. Asus Zenbook UX32VD GPU Fan Replacement: step 5, image 1 of 3 Asus Zenbook UX32VD GPU Fan Replacement: step 5, image 2 of 3 Asus Zenbook UX32VD GPU Fan Replacement: step 5, image 3 of 3
      • Unplug the bundled cable connector.
      • Move the fan as shown in the first picture to better access the connector.
      • Pull the cable away from the connector in the same direction as the individual wires are running.
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      Ask FixBot
    4. Asus Zenbook UX32VD GPU Fan Replacement: step 6, image 1 of 1
      • Remove the fan completely.
      Ask FixBot
Miguel Angel Felix
113 Reputation
1 Guide authored
CSU Fullerton, Team 2-2, Bruce Fall 2015 Member of CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 111
All Time: 2,714
