Asus Zenbook UX32VD HD Web Camera Replacement
    1. Asus Zenbook UX32VD  HD Web Camera Replacement, HD Web Camera: step 1, image 1 of 1
      • Heat the adhesive behind the screen frame with a hair dryer or a heat gun.
      • Use low heat with the heat gun. Over heating could damage delicate electronic components.
      Ask FixBot
    2. Asus Zenbook UX32VD  HD Web Camera Replacement: step 2, image 1 of 3 Asus Zenbook UX32VD  HD Web Camera Replacement: step 2, image 2 of 3 Asus Zenbook UX32VD  HD Web Camera Replacement: step 2, image 3 of 3
      • Insert a spudger between the display screen frame and the back screen panel.
      • Pry the display screen frame away from the back screen panel.
      • Continue to heat and remove the display screen frame along the whole perimeter.
      Ask FixBot
    3. Asus Zenbook UX32VD  HD Web Camera Replacement: step 3, image 1 of 3 Asus Zenbook UX32VD  HD Web Camera Replacement: step 3, image 2 of 3 Asus Zenbook UX32VD  HD Web Camera Replacement: step 3, image 3 of 3
      • Remove display screen frame completely before adhesive cools and hardens.
      Ask FixBot
    4. Asus Zenbook UX32VD  HD Web Camera Replacement: step 4, image 1 of 2 Asus Zenbook UX32VD  HD Web Camera Replacement: step 4, image 2 of 2
      • Unplug the bundled cable connector.
      • Pull the cable away from the connector in the same direction as the individual wires are running.
      • Pull evenly on the full width of the cable so that no individual wires are overly strained.
      Ask FixBot
    5. Asus Zenbook UX32VD  HD Web Camera Replacement: step 5, image 1 of 3 Asus Zenbook UX32VD  HD Web Camera Replacement: step 5, image 2 of 3 Asus Zenbook UX32VD  HD Web Camera Replacement: step 5, image 3 of 3
      • Pry the camera out from the two pins on the left and right of the camera with the tip of a spudger.
      • Remove the camera completely.
      Ask FixBot
Michael Remmel
718 Reputation
3 Guides authored
CSU Fullerton, Team 2-2, Bruce Fall 2015 Member of CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 Members
72 Guides authored
2 Guide Comments
what type/model/code for its replacement camera ? so i cant find it in part store...
tukangsedot - Reply Share
Thank you for the demo. It appears to be easy to replace the camera per your instructions. Kind regards. Mehran Gerami
Mehran Gerami - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 109
All Time: 2,531
