Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Disconnect the battery from the motherboard by gently pulling up and down on the connector.
Use the plastic opening tool to pry open the back cover of the laptop.
Remove the bottom panel of the laptop.
Peel back the warranty sticker to reveal the screw under it.
Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
At the marked locations, unscrew 7 screws with your Phillips 00 Precision Screwdriver.
At the marked locations (under certain components), unscrew 3 screws with your Phillips 00 Precision Screwdriver.
5 other people completed this guide.
