Asus Zenbook UX31E Keyboard Replacement
    1. Asus Zenbook UX31E Keyboard Replacement, Back Cover: step 1, image 1 of 1
      • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
      • Place the screws into a container as to not lose them.
      Ask FixBot
    2. Asus Zenbook UX31E Keyboard Replacement: step 2, image 1 of 1
      • Carefully slide your iFixit Opening Tool between the back panel.
      • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
      Ask FixBot
    1. Asus Zenbook UX31E Keyboard Replacement, Battery: step 3, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement, Battery: step 3, image 2 of 2
      • Disconnect the battery from the motherboard by gently pulling up and down on the connector.
      Ask FixBot
    2. Asus Zenbook UX31E Keyboard Replacement: step 4, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 4, image 2 of 2
      • Using the Phillips #00 screwdriver, remove the screws from the middle and the two corners of the battery.
      Ask FixBot
    3. Asus Zenbook UX31E Keyboard Replacement: step 5, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 5, image 2 of 2
      • Remove the battery. (Picture-1)
      • Picture of what the battery looks like.(Picture-2)
      Ask FixBot
    1. Asus Zenbook UX31E Keyboard Replacement, Speaker: step 6, image 1 of 1
      • Use the plastic opening tool to pry open the back cover of the laptop.
      • Remove the bottom panel of the laptop.
      Ask FixBot
    2. Asus Zenbook UX31E Keyboard Replacement: step 7, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 7, image 2 of 2
      • Remove the screw connecting the speaker component to the motherboard using the screwdriver.
      Ask FixBot
    3. Asus Zenbook UX31E Keyboard Replacement: step 8, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 8, image 2 of 2
      • Disconnect the sound cable from the motherboard.
      Ask FixBot
    4. Asus Zenbook UX31E Keyboard Replacement: step 9, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 9, image 2 of 2
      • Using the plastic opening tool, pry open the speaker component from the computer.
      Ask FixBot
    1. Asus Zenbook UX31E Keyboard Replacement, SSD: step 10, image 1 of 1
      • Attach your Anti-Static Wrist Wrap to something metal as to not shock your system.
      • Peel back the warranty sticker to reveal the screw under it.
      • Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
      Ask FixBot
    2. Asus Zenbook UX31E Keyboard Replacement: step 11, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 11, image 2 of 2
      • Using your hand, pull the SSD out from its slot.
      Ask FixBot
    1. Asus Zenbook UX31E Keyboard Replacement, Fan: step 12, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement, Fan: step 12, image 2 of 2
      • Disconnect the ribbon between the IO and the motherboard on both sides.
      Ask FixBot
    2. Asus Zenbook UX31E Keyboard Replacement: step 13, image 1 of 1
      • Disconnect the fan connector from the motherboard.
      • Pull up the clips on the ribbon connectors.
      Ask FixBot
    3. Asus Zenbook UX31E Keyboard Replacement: step 14, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 14, image 2 of 2
      • Unscrew the two screws that are across each other.
      Ask FixBot
    4. Asus Zenbook UX31E Keyboard Replacement: step 15, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 15, image 2 of 2
      • Using a plastic opening tool, lift the fan off of the laptop.
      • You can now use your hands and carefully pull the fan off the laptop.
      Ask FixBot
    1. Asus Zenbook UX31E Keyboard Replacement, Motherboard: step 16, image 1 of 3 Asus Zenbook UX31E Keyboard Replacement, Motherboard: step 16, image 2 of 3 Asus Zenbook UX31E Keyboard Replacement, Motherboard: step 16, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the 7 screws holding the motherboard in the case with a Phillips #00 screwdriver.
      • Remove the press fit connector attaching the motherboard to the screen.
      • Remove the two cables that are still attached to the motherboard. You will need to use needle nose tweezers to remove these.
      Ask FixBot
    2. Asus Zenbook UX31E Keyboard Replacement: step 17, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 17, image 2 of 2
      • Lift gently and flip the motherboard over in the direction of the track pad.
      • Peel off the the yellow tape.
      • Detach the ZIF connector on the underside of the motherboard connecting it to the keyboard.
      • Remove the motherboard.
      Ask FixBot
    1. Asus Zenbook UX31E Keyboard Replacement, Keyboard: step 18, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement, Keyboard: step 18, image 2 of 2
      • Remove the speaker assembly.
      • Lift gently to avoid damaging the speaker assembly.
      Ask FixBot
    2. Asus Zenbook UX31E Keyboard Replacement: step 19, image 1 of 2 Asus Zenbook UX31E Keyboard Replacement: step 19, image 2 of 2
      • Gently peel back the yellow tape to reveal where the ribbon cable attaches to the track pad.
      Ask FixBot
    3. Asus Zenbook UX31E Keyboard Replacement: step 20, image 1 of 1
      • Remove the 56 screws marked in red circles using a Phillips #000 screwdriver.
      Ask FixBot
    4. Asus Zenbook UX31E Keyboard Replacement: step 21, image 1 of 1
      • Put your hand under the keyboard and gently push the keyboard up and away from the frame of the computer with your fingers.
      • Be very careful to not damage the keyboard itself when removing it.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 92
All Time: 3,632
