Repair Guides
Learn how to fix just about anything with our step-by-step guides.
App
Your pocket repair helper.
FixBot
The friendly AI repair assistant.
Repairability
Learn why fixable products make sense.
Teardowns
Get a sneak peek inside the latest gadgets.
Answers Forum
Share solutions and get help from a friend.
Find Your Community
Find teams, events, and fellow fixers.
Help Out
Help make repair knowledge free and accessible for everyone.
Right to Repair
Learn about the Right to Repair movement and how to be an advocate.
Featured
Quality parts and tools backed by our lifetime guarantee.
Tools
Shop our wide selection of precision tools.
Parts
Shop parts backed by our quality guarantee.
iPhone Batteries
Batteries tested and guaranteed plus a kit with everything you need.
Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
Place the screws into a container as to not lose them.
Carefully slide your iFixit Opening Tool between the back panel.
Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
Disconnect the ribbon between the IO and the motherboard on both sides.
Disconnect the fan connector from the motherboard.
Pull up the clips on the ribbon connectors.
Unscrew the two screws that are across each other.
Using a plastic opening tool, lift the fan off of the laptop.
You can now use your hands and carefully pull the fan off the laptop.
with 4 other contributors
101 Reputation
1 Guide authored
Badges: 5
+2 more badges
UWT-ROSE-W17S1G2
4 Members
72 Guides authored
This guide does not explain how to replace the fan, but how to remove the fan.
How do you insert a new fan? (Specifically, how do you remove the fan from the component of which it is a part?)
Thank you in advance.
Albert - Apr 16, 2018 Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 99
All Time: 2,200
