Asus Zenbook UX31A Fan Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
16
Past 30 Days:
70
All Time:
1,091
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show how to replace the fan of your Asus Zenbook UX31A. This may be necessary if the computer is overheating or the fan is making weird noises.
The fan is responsible for circulating air within the computer to prevent overheating. If the fan has issues, it may lead to overheating.
Before following this guide, make sure to try cleaning out the vents and fan. This can be done using an ESD safe brush and compressed air.
Before you proceed, make sure to power the computer all the way down and disconnect the charging cable.
    1. Asus Zenbook UX31A Fan Replacement, Battery: step 1, image 1 of 2 Asus Zenbook UX31A Fan Replacement, Battery: step 1, image 2 of 2
      • Use a T6 screwdriver to remove the ten 6 mm case screws.
      • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
      • Remove the back cover from the laptop.
      • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
      Ask FixBot
    2. Asus Zenbook UX31A Fan Replacement: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
      Ask FixBot
    3. Asus Zenbook UX31A Fan Replacement: step 3, image 1 of 1
      • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
      • Make sure you pull the connector directly upwards or you could damage the connector
      Ask FixBot
    4. Asus Zenbook UX31A Fan Replacement: step 4, image 1 of 1
      • Remove the battery from the laptop by lifting it up and out.
      Ask FixBot
    1. Asus Zenbook UX31A Fan Replacement, Fan: step 5, image 1 of 2 Asus Zenbook UX31A Fan Replacement, Fan: step 5, image 2 of 2
      • Unclip both ZIF connector tabs by lifting the black tab up and away from the connector.
      • Remove the bridge connector.
      Ask FixBot
    2. Asus Zenbook UX31A Fan Replacement: step 6, image 1 of 3 Asus Zenbook UX31A Fan Replacement: step 6, image 2 of 3 Asus Zenbook UX31A Fan Replacement: step 6, image 3 of 3
      • Use a Phillips #00 screwdriver to remove all seven 6 mm screws that secure the fan and heatsink.
      Ask FixBot
    3. Asus Zenbook UX31A Fan Replacement: step 7, image 1 of 2 Asus Zenbook UX31A Fan Replacement: step 7, image 2 of 2
      • Disconnect the fan connector by pulling on it horizontally until it disconnects.
      • Remove the fan.
      Ask FixBot
Brendan Walsh
230 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 70
All Time: 1,091
