Asus Zenbook UX303L Trackpad Replacement
    1. Asus Zenbook UX303L Trackpad Replacement, Trackpad: step 1, image 1 of 1
      • Make sure the device is turned off and disconnected from the battery charger.
      Ask FixBot
    2. Asus Zenbook UX303L Trackpad Replacement: step 2, image 1 of 3 Asus Zenbook UX303L Trackpad Replacement: step 2, image 2 of 3 Asus Zenbook UX303L Trackpad Replacement: step 2, image 3 of 3
      • Remove all nine screws from the bottom of the device using a T5 screwdriver.
      • Carefully remove the bottom cover.
      Ask FixBot
    3. Asus Zenbook UX303L Trackpad Replacement: step 3, image 1 of 1
      • Remove five Phillips #1 screws from the battery pack.
      Ask FixBot
    4. Asus Zenbook UX303L Trackpad Replacement: step 4, image 1 of 3 Asus Zenbook UX303L Trackpad Replacement: step 4, image 2 of 3 Asus Zenbook UX303L Trackpad Replacement: step 4, image 3 of 3
      • Unhook the red, black, and white coiled switch.
      • Detach the positive and negative red, black, yellow, and white switch from the motherboard.
      • Unhook the black and white coiled wire from the top of the battery pack.
      Ask FixBot
    5. Asus Zenbook UX303L Trackpad Replacement: step 5, image 1 of 3 Asus Zenbook UX303L Trackpad Replacement: step 5, image 2 of 3 Asus Zenbook UX303L Trackpad Replacement: step 5, image 3 of 3
      • Remove the three screws connecting the SSD to the motherboard.
      • Gently lift and pull out the SSD.
      Ask FixBot
    6. Asus Zenbook UX303L Trackpad Replacement: step 6, image 1 of 3 Asus Zenbook UX303L Trackpad Replacement: step 6, image 2 of 3 Asus Zenbook UX303L Trackpad Replacement: step 6, image 3 of 3
      • Remove the screw attaching the cooling fan to the motherboard.
      • Lift and remove the cooling fan.
      Ask FixBot
    7. Asus Zenbook UX303L Trackpad Replacement: step 7, image 1 of 2 Asus Zenbook UX303L Trackpad Replacement: step 7, image 2 of 2
      • Remove the four Phillips #1 screws attached to the black covered copper bar next to the cooling fan.
      • Gently lift and remove the copper bar.
      Ask FixBot
    8. Asus Zenbook UX303L Trackpad Replacement: step 8, image 1 of 3 Asus Zenbook UX303L Trackpad Replacement: step 8, image 2 of 3 Asus Zenbook UX303L Trackpad Replacement: step 8, image 3 of 3
      • Remove the silver tape to reveal the fourth screw on the motherboard.
      • Detach the motherboard by removing the four Phillips #1 screws.
      • Detach the white wire connecting the motherboard by lifting the black flap and pulling it out.
      Ask FixBot
    9. Asus Zenbook UX303L Trackpad Replacement: step 9, image 1 of 1
      Tool used on this step:
      Buy
      • By using ESD-safe tweezers, remove the gray colored wire.
      • Remove the white wire using tweezers.
      • Remove the blue colored wire by lifting the black flap and pulling the blue flap out.
      Ask FixBot
    10. Asus Zenbook UX303L Trackpad Replacement: step 10, image 1 of 3 Asus Zenbook UX303L Trackpad Replacement: step 10, image 2 of 3 Asus Zenbook UX303L Trackpad Replacement: step 10, image 3 of 3
      • Remove the white wire with the blue ends by lifting the black flap with tweezers and gently pulling out.
      • Gently remove the silver tape using tweezers.
      • Remove the Phillips #1 screws.
      Ask FixBot
    11. Asus Zenbook UX303L Trackpad Replacement: step 11, image 1 of 2 Asus Zenbook UX303L Trackpad Replacement: step 11, image 2 of 2
      • Place the plastic opening tools under the trackpad.
      • Gently pull out and remove the trackpad.
      Ask FixBot
3 other people completed this guide.
Fredis Benitez
259 Reputation
1 Guide authored
1 Guide Comment
This laptop comes with a very bad trackpad, it has very low resolution. Do you think it can be updated?
eduugr - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 106
All Time: 6,822
