Asus Zenbook UX303L Hard Drive Replacement
Views: 38K
View statistics:
Past 24 Hours:
3
Past 7 Days:
40
Past 30 Days:
159
All Time:
37,953
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 21
21 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Follow this guide if you need to replace the hard drive of your Asus Zenbook UX303L. The hard drive is the part of the computer where all the data is stored on the computer.  Whether your hard drive is failing or needs a storage upgrade, this guide will show you step by step how to remove and replace your hard drive.  It is important to remember when working on any computer to wear an anti-static wrist band so that any static electricity doesn’t damage the internal components of the computer.
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
    1. Asus Zenbook UX303L Hard Drive Replacement, SSD: step 1, image 1 of 1
      • Make sure the device is turned off and disconnected from the battery charger.
      Ask FixBot
    2. Asus Zenbook UX303L Hard Drive Replacement: step 2, image 1 of 3 Asus Zenbook UX303L Hard Drive Replacement: step 2, image 2 of 3 Asus Zenbook UX303L Hard Drive Replacement: step 2, image 3 of 3
      • Remove all nine screws from the bottom of the device using a T5 screwdriver.
      • Remove two additional screws, if present, from beneath the rubber pads. (Pry up each rubber pad to access its screw.)
      • Carefully remove the bottom cover. The cover doesn't just lift up, you have to lift it to a approx. 45° angle, then pull towards the exterior (there are two small plastic claws that maintain the cover attached)
      Ask FixBot
    3. Asus Zenbook UX303L Hard Drive Replacement: step 3, image 1 of 1
      • Remove the five screws attaching the battery pack by using a PH-1 screwdriver.
      Ask FixBot
    4. Asus Zenbook UX303L Hard Drive Replacement: step 4, image 1 of 2 Asus Zenbook UX303L Hard Drive Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Unhook the black, red, and white switch using the tweezers.
      Ask FixBot
    5. Asus Zenbook UX303L Hard Drive Replacement: step 5, image 1 of 2 Asus Zenbook UX303L Hard Drive Replacement: step 5, image 2 of 2
      • Detach the positive and negative black, white, yellow, and red switch with the use of tweezers.
      Ask FixBot
    6. Asus Zenbook UX303L Hard Drive Replacement: step 6, image 1 of 3 Asus Zenbook UX303L Hard Drive Replacement: step 6, image 2 of 3 Asus Zenbook UX303L Hard Drive Replacement: step 6, image 3 of 3
      • Unhook the black and white coiled wire using the tweezers.
      Ask FixBot
    7. Asus Zenbook UX303L Hard Drive Replacement: step 7, image 1 of 3 Asus Zenbook UX303L Hard Drive Replacement: step 7, image 2 of 3 Asus Zenbook UX303L Hard Drive Replacement: step 7, image 3 of 3
      • Remove the 3 screws surrounding the hard drive using the PH-1 screwdriver.
      • Gently lift and detach the hard drive, and pull it out.
      • If your model has never been opened, you might have this "cushion sticker" that makes it difficult to unplug the hard drive. You can just peel it and put it back later.
      Ask FixBot
21 other people completed this guide.
Cindy Lopez
654 Reputation
1 Guide authored
4 Guide Comments
This guide worked fine for me. I have two suggestions that made my disassembly easier.
First, I used the standard blue guitar pick to gently pop the back cover off near the hinge. Nothing special here.
Second, the power connector in Step 5 lifts up to disconnect. I found using the blue pry bar to lift the side of the connector much easier than tweezers.
Good, clear, complete guide.
Greg - Reply Share
Great guide, worked for me.
I second Greg’s comment: Step 5’s battery connector lifts up, so using something like iFixit’s blue pry bar might be easier.
Additionally, for Step 7, the 3 screws might be hidden under cushion stickers. These can be peeled off and put back later.
Chawit Leosrisook - Reply Share
Mein Laptop geht nach dem Umbau nicht mehr einzuschalten. Selbst die kleine Akku LED leuchtet nicht mehr, sobald das Netzkabel dran gesteckt ist. :(
Steff - Reply Share
I have the same issue. After putting everything back together, there is no charging light when the power cable is connect. Also nothing happens when pressing the power button.
I tried removing the battery and the CMOS battery, holding the power button for 30-40 seconds before re-assemblingt the device. But that did not help.
Felix - Reply Share
Past 24 Hours: 3
Past 7 Days: 40
Past 30 Days: 159
All Time: 37,953
