Asus Zenbook UX21e Cooling System Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
79
All Time:
1,618
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The Asus Zenbook UX21e has a simple cooling system that can be quickly removed and cleaned or replaced. This guide involves following the battery replacement guide initially, before removing a protective plastic cover to disconnect the fan. It is then possible to unscrew and disconnect the fan to remove it.
After removing the cooling system, you must clean any theremal paste apply new thermal paste when you reinstall the cooling system.
Tools
    1. Asus Zenbook UX21e Cooling System Replacement, Battery: step 1, image 1 of 3 Asus Zenbook UX21e Cooling System Replacement, Battery: step 1, image 2 of 3 Asus Zenbook UX21e Cooling System Replacement, Battery: step 1, image 3 of 3
      • Using a T4 Torx screwdriver, unscrew the ten screws lining the bottom cover. Then, proceed to remove the bottom cover by sliding it out parallel toward the back of the computer.
      • There are two length of screws. Eight screws are 3mm and two are 5mm. The two 5mm screws always go into the two center holes along the back edge.
      Ask FixBot
    2. Asus Zenbook UX21e Cooling System Replacement: step 2, image 1 of 3 Asus Zenbook UX21e Cooling System Replacement: step 2, image 2 of 3 Asus Zenbook UX21e Cooling System Replacement: step 2, image 3 of 3
      • Using an iFixit opening tool and your other hand, gently lift the connector up from the tape wrapped around the connector wires and pry the connector from the motherboard.
      Ask FixBot
    3. Asus Zenbook UX21e Cooling System Replacement: step 3, image 1 of 1
      • Remove the battery by unscrewing the five 3mm screws using a Phillips #1 screwdriver.
      • One at each corner and one in the center.
      Ask FixBot
    4. Asus Zenbook UX21e Cooling System Replacement: step 4, image 1 of 2 Asus Zenbook UX21e Cooling System Replacement: step 4, image 2 of 2
      • Lift the battery directly up and remove it from the device.
      Ask FixBot
    1. Asus Zenbook UX21e Cooling System Replacement, Cooling System: step 5, image 1 of 3 Asus Zenbook UX21e Cooling System Replacement, Cooling System: step 5, image 2 of 3 Asus Zenbook UX21e Cooling System Replacement, Cooling System: step 5, image 3 of 3
      • Remove the plastic piece (labeled M3 10) sitting on top of the fan by lifting from one edge and peeling it over.
      Ask FixBot
    2. Asus Zenbook UX21e Cooling System Replacement: step 6, image 1 of 2 Asus Zenbook UX21e Cooling System Replacement: step 6, image 2 of 2
      • Disconnect fan from motherboard by pulling the small white and blue connector from its socket.
      Ask FixBot
    3. Asus Zenbook UX21e Cooling System Replacement: step 7, image 1 of 2 Asus Zenbook UX21e Cooling System Replacement: step 7, image 2 of 2
      • Remove the seven 3mm screws that hold the cooling system down using a Phillips #1 screwdriver.
      • Four are along the heat sink above the CPU, one is on the side of smaller heat sink to the left of the CPU heat sink. Two are along the edge of the fan.
      • Remove the cooling system from the device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Make sure to clean the CPU with a clean and dry cloth and compressed air. You must also squeeze new thermal paste onto the CPU before reassembling.
Zachary Eslick
756 Reputation
5 Guides authored
Cal Poly, Team S22-G1, Maness Spring 2018 Member of Cal Poly, Team S22-G1, Maness Spring 2018
CPSU-MANESS-S18S22G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 79
All Time: 1,618
