Introduction
This is a short guide on removing the bottom cover on the Asus Zenbook UM325U. Once removed, we can directly access and replace the SSD or Battery. Other items would require further disassembly not covered here.
Be advised: two Torx screws are hidden under the two back rubber 'feet' of the laptop.
This is the inner surface of the bottom cover. Notice the multiple plastic clips or tabs that secure the bottom to the top of the case.
Use a spudger or pick to pry these open, start from the front, working towards the back. (where the screen hinges)
Now that the case is open you can access the SSD or Battery for repair or replacement.
