Asus ZenWatch 2 Motherboard Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
84
All Time:
3,309
Comments: 6
6 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The motherboard housed within the Asus ZenWatch 2 serves as the primary root of function for the entire device. It connects many of the hardware components and allows the installed software to function properly. Any damage sustained to the part will likely result in the device's inability to operate as intended. If damage to the motherboard occurs, replacing it is a simple process involving only a few tools.
Parts
Tools
    1. Asus ZenWatch 2 Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Remove the four 3.5mm screws using a T5 screwdriver to open the faceplate.
      Ask FixBot
    2. Asus ZenWatch 2 Motherboard Replacement: step 2, image 1 of 2 Asus ZenWatch 2 Motherboard Replacement: step 2, image 2 of 2
      • Remove the two 1.8mm silver screws using the PH00 screwdriver.
      Ask FixBot
    3. Asus ZenWatch 2 Motherboard Replacement: step 3, image 1 of 2 Asus ZenWatch 2 Motherboard Replacement: step 3, image 2 of 2
      • Slide the spudger under the gold-plated connection ribbon and lift to disconnect from the motherboard.
      Ask FixBot
    4. Asus ZenWatch 2 Motherboard Replacement: step 4, image 1 of 2 Asus ZenWatch 2 Motherboard Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Pull up on the motherboard using tweezers to detach it from the watch.
      Ask FixBot
Andrew
335 Reputation
2 Guides authored
USF Tampa, Team S1-G1, Leahy Spring 2017 Member of USF Tampa, Team S1-G1, Leahy Spring 2017
USFT-LEAHY-S17S1G1
3 Members
60 Guides authored
6 Guide Comments
Step 3 requires three different connectors to be removed from the mainboard. Not one. Attempting to remove the mainboard after only disconnecting the gold-plated connector can result in damaged digitizer/display cable.
s3ae - Reply Share
Out of curiosity, I don’t see the battery hiding in any of the pictures. Is it glued or otherwise attached to the backplate of the watch, and since you’re focused on the mainboard, we’re not seeing it for that reason? Thanks!
MD5Hash - Reply Share
Battery is actually stuck to the bottom side of the case. It looks to be pretty easy to replace. Connection is done with 4 sets of pins (at least 2 for battery)
Jean-Guy Rivard - Reply Share
Where can you purchase a replacement motherboard?
Tasha Kanahele - Reply Share
My zenfone wach 2 all function not showing please help me
Akhtar - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 84
All Time: 3,309
