Up to 20% off select tools
Asus ZenScreen LCD Disassembly
Views: 1.4K
View statistics:
Past 24 Hours:
7
Past 7 Days:
52
Past 30 Days:
223
All Time:
1,352
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
The ASUS ZenScreen MB16ACV, is a portable monitor, but once you crack the display, it's worthless. Or is it? You can easily replace the display by following these instructions!
    1. Asus ZenScreen LCD Disassembly, Prepare for Disassembly: step 1, image 1 of 2 Asus ZenScreen LCD Disassembly, Prepare for Disassembly: step 1, image 2 of 2
      • Start by laying the monitor flat on a work surface
      Ask FixBot
    2. Asus ZenScreen LCD Disassembly, Pry off the Bezel: step 2, image 1 of 2 Asus ZenScreen LCD Disassembly, Pry off the Bezel: step 2, image 2 of 2
      • Start carefully prying on the edges of the bezel with a plastic pry tool.
      • BE CAREFUL OF THE BOTTOM SCREEN GLUE, IT MAY CRACK, BEND, OR BREAK YOUR BEZEL.
      Ask FixBot
    3. Asus ZenScreen LCD Disassembly, Taking off the Display: step 3, image 1 of 3 Asus ZenScreen LCD Disassembly, Taking off the Display: step 3, image 2 of 3 Asus ZenScreen LCD Disassembly, Taking off the Display: step 3, image 3 of 3
      • Now that the bezel is off, flip it on it's screen, and shake gently to remove the display.
      Ask FixBot
    4. Asus ZenScreen LCD Disassembly, Unplug the LCD: step 4, image 1 of 3 Asus ZenScreen LCD Disassembly, Unplug the LCD: step 4, image 2 of 3 Asus ZenScreen LCD Disassembly, Unplug the LCD: step 4, image 3 of 3
      • Lift the latch on the cable that is colored red above the plug and fully push it back.
      • Pull gently on the cable, and it should pop right out!
      Ask FixBot
Author
with
Duck
264 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 52
Past 30 Days: 223
All Time: 1,352
