Asus ZenFone 5 Battery Replacement
    1. Asus ZenFone 5 Battery Replacement, Battery: step 1, image 1 of 3 Asus ZenFone 5 Battery Replacement, Battery: step 1, image 2 of 3 Asus ZenFone 5 Battery Replacement, Battery: step 1, image 3 of 3
      • Insert a SIM card removal tool or the end of a paperclip into the small hole on the lefthand side of the phone to release the SIM card.
      • Pull out the SIM card tray.
      Ask FixBot
    2. Asus ZenFone 5 Battery Replacement: step 2, image 1 of 3 Asus ZenFone 5 Battery Replacement: step 2, image 2 of 3 Asus ZenFone 5 Battery Replacement: step 2, image 3 of 3
      • It may help to apply heat to the back cover using either a heat gun or an iOpener before starting to remove the cover.
      • Use a plastic opening pick to pry into the crease between the back cover and the midframe of the phone.
      • Move all the way around the phone until the back cover is separated from the rest of the phone.
      • The images show a metal spudger being used to pry open the back cover. However, this process is not recommended, as it poses a puncture risk to the battery.
      Ask FixBot
    3. Asus ZenFone 5 Battery Replacement: step 3, image 1 of 3 Asus ZenFone 5 Battery Replacement: step 3, image 2 of 3 Asus ZenFone 5 Battery Replacement: step 3, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the six screws across the top mid frame and gently lift the top assembly piece. It should detach easily and can be set aside.
      Ask FixBot
    4. Asus ZenFone 5 Battery Replacement: step 4, image 1 of 3 Asus ZenFone 5 Battery Replacement: step 4, image 2 of 3 Asus ZenFone 5 Battery Replacement: step 4, image 3 of 3
      • Use a plastic opening tool to release the red square that is holding the bottom assembly piece from the frame.
      • Using a Phillips #00 screwdriver, remove the five screws from the bottom midframe.
      • Gently remove the bottom midframe.
      Ask FixBot
    5. Asus ZenFone 5 Battery Replacement: step 5, image 1 of 2 Asus ZenFone 5 Battery Replacement: step 5, image 2 of 2
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Use a halberd spudger to pry up the battery's press fit connector from the motherboard.
      • Gently pry the battery out of the case, taking care not to bend or puncture the battery.
      • It may help to apply a bit of heat through the screen to loosen the battery adhesive.
      Ask FixBot
1 Guide Comment
Wait, Asus Zenfone 5 (ZE620KL, ZF620KL) has only 3300 mAh battery capacity. Why in the image above the battery label say it's 4000 mAh?
Jufans Anurwan - Reply Share
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 117
All Time: 6,543
