Asus ZenFone 3 Zoom Screen Replacement
    1. Asus ZenFone 3 Zoom Screen Replacement, Screen Replacement: step 1, image 1 of 2 Asus ZenFone 3 Zoom Screen Replacement, Screen Replacement: step 1, image 2 of 2
      • Use sim card attachment for the screwdriver found in the IFIXIT box to remove the sim card tray from the phone.
      Ask FixBot
    2. Asus ZenFone 3 Zoom Screen Replacement: step 2, image 1 of 1
      • Remove the 3.5 mm screws on both sides of the charging port, at the bottom of the phone, using the T2 screwdriver.
      Ask FixBot
    3. Asus ZenFone 3 Zoom Screen Replacement: step 3, image 1 of 2 Asus ZenFone 3 Zoom Screen Replacement: step 3, image 2 of 2
      • Use the opening tool to separate the screen and the plastic body of the phone.
      Ask FixBot
    4. Asus ZenFone 3 Zoom Screen Replacement: step 4, image 1 of 1
      • Utilize the PH #00 attachment to remove the two 3.3 mm screws in the bracket to the top left of the battery.
      Ask FixBot
    5. Asus ZenFone 3 Zoom Screen Replacement: step 5, image 1 of 1
      • After removing the bracket and screws, pull up on the battery from the bottom of the unit and set aside.
      Ask FixBot
    6. Asus ZenFone 3 Zoom Screen Replacement: step 6, image 1 of 2 Asus ZenFone 3 Zoom Screen Replacement: step 6, image 2 of 2
      • Remove all three screws near the top of the phone with the PH #00.
      • The top right and left screws are 3.25 mm.
      • The middle screw is 2.65 mm.
      Ask FixBot
    7. Asus ZenFone 3 Zoom Screen Replacement: step 7, image 1 of 1
      • De-solder the single black speaker wire attached on the left side of the phone.
      Ask FixBot
    8. Asus ZenFone 3 Zoom Screen Replacement: step 8, image 1 of 2 Asus ZenFone 3 Zoom Screen Replacement: step 8, image 2 of 2
      • Use the flat-edge side of iFixIt plastic spudger to detach both of the ribbon cables off of the motherboard at their connection point.
      Ask FixBot
    9. Asus ZenFone 3 Zoom Screen Replacement: step 9, image 1 of 2 Asus ZenFone 3 Zoom Screen Replacement: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Use the tweezers to lift up on the edges of the motherboard located above where the battery was, then remove the motherboard.
      Ask FixBot
    10. Asus ZenFone 3 Zoom Screen Replacement: step 10, image 1 of 2 Asus ZenFone 3 Zoom Screen Replacement: step 10, image 2 of 2
      • Remove the speaker cover at the bottom of the casing by taking out all five 3.25 mm screws with the PH #00.
      Ask FixBot
    11. Asus ZenFone 3 Zoom Screen Replacement: step 11, image 1 of 1
      • Gently pry off the ribbon cable from speaker housing with the flat-edge side of the iFixit plastic spudger.
      Ask FixBot
    12. Asus ZenFone 3 Zoom Screen Replacement: step 12, image 1 of 1
      • Remove the speaker once exposed.
      Ask FixBot
    13. Asus ZenFone 3 Zoom Screen Replacement: step 13, image 1 of 1
      • Use iOpener to soften the adhesive keeping the screen on the device.
      Ask FixBot
    14. Asus ZenFone 3 Zoom Screen Replacement: step 14, image 1 of 1
      • Pry off the screen beginning at the right-hand side toward the bottom of the phone with the plastic flat-edge spudger.
      Ask FixBot
    15. Asus ZenFone 3 Zoom Screen Replacement: step 15, image 1 of 1
      • Progress around the perimeter of the phone with the pry tool till the screen is off.
      Ask FixBot
    16. Asus ZenFone 3 Zoom Screen Replacement: step 16, image 1 of 2 Asus ZenFone 3 Zoom Screen Replacement: step 16, image 2 of 2
      • Remove the screen by pulling the attached ribbon cable out through the exposed opening.
      Ask FixBot
    17. Asus ZenFone 3 Zoom Screen Replacement: step 17, image 1 of 1
      • The finished product will be a screen with nothing attached to the body of the phone.
      Ask FixBot
Finish Line
Luke Theiss
271 Reputation
1 Guide authored
IUPUI, Team S2-G3, Harley Summer 2019 Member of IUPUI, Team S2-G3, Harley Summer 2019
IUPUI-HARLEY-SU19S2G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 65
All Time: 3,169
