Asus ZenBook UX330U Battery Replacement
Views: 24K
View statistics:
Past 24 Hours:
6
Past 7 Days:
34
Past 30 Days:
191
All Time:
24,104
Comments: 28
9 comments on steps, 19 guide comments.
Go to guide comments
Completed: 24
24 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If your Asus ZenBook UX330U or UX330UA never holds a charge or has a short battery life, then you may need to replace the battery. Before using this guide, look at the troubleshooting page located here for possible fixes that do not require any disassembly. This guide can be used to remove the back panel and battery for the ASUS ZenBook UX330U or UX330UA.
The battery is an essential part of the Asus Zenbook- it gives your laptop life. Before removing the battery, inspect it to make sure that it is not swollen, and that all power has been discharged from the battery. For more information about battery safety, please look at this guide that iFixit has provided.
Before beginning any device disassembly, please power off and unplug your device.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Asus ZenBook UX330U Battery Replacement, Battery: step 1, image 1 of 3 Asus ZenBook UX330U Battery Replacement, Battery: step 1, image 2 of 3 Asus ZenBook UX330U Battery Replacement, Battery: step 1, image 3 of 3
      • Before starting any device dissasembly, please put on the anti-static bracelet provided by iFixit. Make sure the metal part of the bracelet is touching your skin.
      • Remove the alligator clip at the end of the bracelet by simply pulling it off, to reveal the bullet connector.
      • Insert the bullet connector into the ground port of an outlet.
      • Make sure to keep the bracelet on at all times while disassembling your device, to prevent ESD to the components.
      Ask FixBot
    2. Asus ZenBook UX330U Battery Replacement: step 2, image 1 of 2 Asus ZenBook UX330U Battery Replacement: step 2, image 2 of 2
      • Power off the device and make sure it is physically unplugged before starting any disassembly procedures.
      • Remove the eight 3.1 mm screws using the T5 Torx screwdriver.
      • Remove the longer 5.1 mm screw using the T5 Torx screwdriver.
      Ask FixBot
    3. Asus ZenBook UX330U Battery Replacement: step 3, image 1 of 3 Asus ZenBook UX330U Battery Replacement: step 3, image 2 of 3 Asus ZenBook UX330U Battery Replacement: step 3, image 3 of 3
      • Use a Jimmy or a spudger to pry off the two rubber feet that are closest to the hinge.
      • Unscrew the two 5.6mm screws that were underneath the rubber feet using the Philips #0 screwdriver bit.
      • The rubber feet may be difficult to remove. Do not hesitate to use more force to remove the feet, if necessary.
      Ask FixBot
    4. Asus ZenBook UX330U Battery Replacement: step 4, image 1 of 2 Asus ZenBook UX330U Battery Replacement: step 4, image 2 of 2
      • Press the suction handle on the center of the back cover, and gently lift up.
      • You may need to wiggle the back cover as you lift it in order to take it off easily.
      Ask FixBot
    5. Asus ZenBook UX330U Battery Replacement: step 5, image 1 of 2 Asus ZenBook UX330U Battery Replacement: step 5, image 2 of 2
      • Unscrew the six 3.7mm screws using the Philips #0 screwdriver bit.
      • Be extra cautious when handling the battery. If the battery looks swollen or damaged, consult this guide.
      Ask FixBot
    6. Asus ZenBook UX330U Battery Replacement: step 6, image 1 of 3 Asus ZenBook UX330U Battery Replacement: step 6, image 2 of 3 Asus ZenBook UX330U Battery Replacement: step 6, image 3 of 3
      • Remove the four 2.8mm screws from the motherboard ribbon connector using the Philips #0 screwdriver bit.
      • You may have to pull back the black tape located on the bottom right motherboard connector screw. This tape is not necessary for the functionality of the device and can be discarded if necessary.
      Ask FixBot
    7. Asus ZenBook UX330U Battery Replacement: step 7, image 1 of 3 Asus ZenBook UX330U Battery Replacement: step 7, image 2 of 3 Asus ZenBook UX330U Battery Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the motherboard ribbon connector by pulling up on the metal ends with the blunt nose tweezers.
      • You may have to hold down the black tape in order to be able to lift up the connector.
      • To reconnect the motherboard ribbon, simply press the ends of the ribbon on top of the connector. This should require minimal force.
      Ask FixBot
    8. Asus ZenBook UX330U Battery Replacement: step 8, image 1 of 3 Asus ZenBook UX330U Battery Replacement: step 8, image 2 of 3 Asus ZenBook UX330U Battery Replacement: step 8, image 3 of 3
      • Pull back the silver battery connector lock with the blunt nose tweezers. This should slide back and should require minimal force.
      • Lift the battery connector vertically using the blunt nose tweezers to remove it from the socket.
      Ask FixBot
    9. Asus ZenBook UX330U Battery Replacement: step 9, image 1 of 2 Asus ZenBook UX330U Battery Replacement: step 9, image 2 of 2
      • Gently lift the battery out of the chassis of the device.
      • Make sure that you do not bend the battery.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
24 other people completed this guide.
19 Guide Comments
It would be nice if you mentioned the model of battery the Asus UX330 uses, even of you don’t carry it.
Other than that, great instructions. I’ve ordered tools from you folks and would have ordered the battery if you stocked it.
My wife can hardly wait for me to fix her computer!
Thanks!
Mike
mavery - Reply Share
Glad the guide was helpful! We (students) did this project as part of a course for our university and compiled all the information ourselves. I don’t remember if we ever found a part number for the battery, which would explain why one wasn’t provided in the guide.
Scott Hansard - Reply Share
The battery model number is C31N1602
dunxd - Reply Share
Your instructions made the battery replacement as smooth as silk! I really hate getting into laptops, but you made it (almost) painless.
The problems were, as usual, my big hands and my aging eyes.
Thanks,
Mike
I was pleasantly surprised at how easy the battery replacement turned out to be, partly due to the design of the ASUS UX330, but also due to the excellent repair guide. Thanks!
Michael Goss - Reply Share
Past 24 Hours: 6
Past 7 Days: 34
Past 30 Days: 191
All Time: 24,104
