Asus ZenBook Flip UX360C Screen Replacement
    1. Asus ZenBook Flip UX360C Screen Replacement, Screen: step 1, image 1 of 2 Asus ZenBook Flip UX360C Screen Replacement, Screen: step 1, image 2 of 2
      • Use a spudger to pry out the two rubber grommets from the front of the screen.
      • Remove the two 4mm Phillips Head #1 screws behind the grommets.
      Ask FixBot
    2. Asus ZenBook Flip UX360C Screen Replacement: step 2, image 1 of 1
      • Use a large plastic opening tool to work around the outside of the screen and gently separate the two halves.
      Ask FixBot
    3. Asus ZenBook Flip UX360C Screen Replacement: step 3, image 1 of 1
      • Remove the two 2 mm Phillips #00 camera screws.
      • Remove the 2 mm Phillips #0 upper circuit board screw.
      • Remove the 2 mm Phillips #0 lower circuit board screw.
      Ask FixBot
    4. Asus ZenBook Flip UX360C Screen Replacement: step 4, image 1 of 2 Asus ZenBook Flip UX360C Screen Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to unplug the two ribbon cables from the top half of the screen.
      • Detach the upper circuit board cable using the same method.
      Ask FixBot
    5. Asus ZenBook Flip UX360C Screen Replacement: step 5, image 1 of 3 Asus ZenBook Flip UX360C Screen Replacement: step 5, image 2 of 3 Asus ZenBook Flip UX360C Screen Replacement: step 5, image 3 of 3
      • On the bottom half of the screen remove the screen connection.
      • Disconnect the lower circuit board cable.
      • Separate the wiring from the casing, and remove the screen.
      Ask FixBot
Kristopher Bright
397 Reputation
3 Guides authored
IUPUI, Team 1-4, Harley Spring 2022 Member of IUPUI, Team 1-4, Harley Spring 2022
IUPUI-HARLEY-S22S1G4
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 116
All Time: 3,610
