Asus Zen AiO Pro Z240IC Screen Replacement
    1. Asus Zen AiO Pro Z240IC Screen Replacement, Screen: step 1, image 1 of 2 Asus Zen AiO Pro Z240IC Screen Replacement, Screen: step 1, image 2 of 2
      • Use the plastic opening tool to pry off the black plastic strip at the bottom of the screen by wiggling the tool between the strip and the screen.
      • The strip is held in place with adhesive. You may hear a crackling sound as the strip is peeled off.
      • Run the opening tool slowly along the base of the screen, peeling the black strip back, until the opposite end of the screen is reached.
      Ask FixBot
    2. Asus Zen AiO Pro Z240IC Screen Replacement: step 2, image 1 of 2 Asus Zen AiO Pro Z240IC Screen Replacement: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the seven (7) 4.8 mm screws from the base of the screen.
      Ask FixBot
    3. Asus Zen AiO Pro Z240IC Screen Replacement: step 3, image 1 of 3 Asus Zen AiO Pro Z240IC Screen Replacement: step 3, image 2 of 3 Asus Zen AiO Pro Z240IC Screen Replacement: step 3, image 3 of 3
      • Place the computer on its back, facing up.
      • Wedge the plastic opening tool in between the screen and the bezel of the aluminum computer casing.
      • Move the tool along the entire edge of the screen with an up-and-down prying motion to loosen the screen from the casing. Do not lift the entire screen away from the computer yet.
      • The screen is held in place by plastic tabs. These will create a popping sound when loosened.
      • The screen assembly will flex as it is pried off. Do not bend the screen too far or the glass screen could shatter.
      Ask FixBot
    4. Asus Zen AiO Pro Z240IC Screen Replacement: step 4, image 1 of 1
      • Lift the screen from the bottom edge by about 6 inches. Prop it open with one hand.
      • Look inside the computer and locate five (5) cables that connect the embedded components of the screen (camera, microphone, etc.) to the rest of the computer.
      Ask FixBot
    5. Asus Zen AiO Pro Z240IC Screen Replacement: step 5, image 1 of 3 Asus Zen AiO Pro Z240IC Screen Replacement: step 5, image 2 of 3 Asus Zen AiO Pro Z240IC Screen Replacement: step 5, image 3 of 3
      • Remove the two (2) cables that are connected to the computer by white, rectangular terminal blocks by pulling straight out on the plug.
      • The cables and wires in these steps are delicate; do not tug on the individual wires that make up each cable.
      Ask FixBot
    6. Asus Zen AiO Pro Z240IC Screen Replacement: step 6, image 1 of 3 Asus Zen AiO Pro Z240IC Screen Replacement: step 6, image 2 of 3 Asus Zen AiO Pro Z240IC Screen Replacement: step 6, image 3 of 3
      • Use a finger to lift the plastic locking flaps that hold the remaining three (3) ribbon cables in place.
      • Remove the cables from their terminals by slipping them away from their connectors.
      • The black line on the ribbon cables mark the connecting region. When reinstalling, insert the cable up to this line so the locking flap covers it.
      Ask FixBot
2 other people completed this guide.
Jessica Lerena
651 Reputation
4 Guides authored
Cal Poly, Team S4-G1, Livingston Fall 2017 Member of Cal Poly, Team S4-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G1
5 Members
120 Guides authored
2 Guide Comments
Can anyone tell me where I can find this display / lcd for sale?
Thanks
André - Reply Share
In step 6 you are removing a ribbon cable with your fingernail. The same cable is damaged for me. Can you share the part number of this cable? I can see this a label is on this cable. I believe this is enabling the digitiser to work. I contacted Asus UK and they have no clue. Thanks
Paul Kormany - Reply Share
Past 24 Hours: 10
Past 7 Days: 42
Past 30 Days: 133
All Time: 7,658
