Asus Zen AiO Pro Z240IC Fan Replacement
    1. Asus Zen AiO Pro Z240IC Fan Replacement, Screen: step 1, image 1 of 2 Asus Zen AiO Pro Z240IC Fan Replacement, Screen: step 1, image 2 of 2
      • Use the plastic opening tool to pry off the black plastic strip at the bottom of the screen by wiggling the tool between the strip and the screen.
      • The strip is held in place with adhesive. You may hear a crackling sound as the strip is peeled off.
      • Run the opening tool slowly along the base of the screen, peeling the black strip back, until the opposite end of the screen is reached.
      Ask FixBot
    2. Asus Zen AiO Pro Z240IC Fan Replacement: step 2, image 1 of 2 Asus Zen AiO Pro Z240IC Fan Replacement: step 2, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the seven (7) 4.8 mm screws from the base of the screen.
      Ask FixBot
    3. Asus Zen AiO Pro Z240IC Fan Replacement: step 3, image 1 of 3 Asus Zen AiO Pro Z240IC Fan Replacement: step 3, image 2 of 3 Asus Zen AiO Pro Z240IC Fan Replacement: step 3, image 3 of 3
      • Place the computer on its back, facing up.
      • Wedge the plastic opening tool in between the screen and the bezel of the aluminum computer casing.
      • Move the tool along the entire edge of the screen with an up-and-down prying motion to loosen the screen from the casing. Do not lift the entire screen away from the computer yet.
      • The screen is held in place by plastic tabs. These will create a popping sound when loosened.
      • The screen assembly will flex as it is pried off. Do not bend the screen too far or the glass screen could shatter.
      Ask FixBot
    4. Asus Zen AiO Pro Z240IC Fan Replacement: step 4, image 1 of 1
      • Lift the screen from the bottom edge by about 6 inches. Prop it open with one hand.
      • Look inside the computer and locate five (5) cables that connect the embedded components of the screen (camera, microphone, etc.) to the rest of the computer.
      Ask FixBot
    5. Asus Zen AiO Pro Z240IC Fan Replacement: step 5, image 1 of 3 Asus Zen AiO Pro Z240IC Fan Replacement: step 5, image 2 of 3 Asus Zen AiO Pro Z240IC Fan Replacement: step 5, image 3 of 3
      • Remove the two (2) cables that are connected to the computer by white, rectangular terminal blocks by pulling straight out on the plug.
      • The cables and wires in these steps are delicate; do not tug on the individual wires that make up each cable.
      Ask FixBot
    6. Asus Zen AiO Pro Z240IC Fan Replacement: step 6, image 1 of 3 Asus Zen AiO Pro Z240IC Fan Replacement: step 6, image 2 of 3 Asus Zen AiO Pro Z240IC Fan Replacement: step 6, image 3 of 3
      • Use a finger to lift the plastic locking flaps that hold the remaining three (3) ribbon cables in place.
      • Remove the cables from their terminals by slipping them away from their connectors.
      • The black line on the ribbon cables mark the connecting region. When reinstalling, insert the cable up to this line so the locking flap covers it.
      Ask FixBot
    1. Asus Zen AiO Pro Z240IC Fan Replacement, Fan: step 7, image 1 of 2 Asus Zen AiO Pro Z240IC Fan Replacement, Fan: step 7, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the three (3) 4.8 mm screws from the fan unit.
      • Remove the cable connecting the fan to the motherboard by pulling the cable out of its socket.
      Ask FixBot
    2. Asus Zen AiO Pro Z240IC Fan Replacement: step 8, image 1 of 1
      • Remove the fan by peeling off the black electrical tape holding it against the heat sink vents.
      Ask FixBot
Anthony Muench
475 Reputation
2 Guides authored
Cal Poly, Team S4-G1, Livingston Fall 2017 Member of Cal Poly, Team S4-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G1
5 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 108
All Time: 3,053
