Asus Z54C-JS31 WiFi Card Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
8
Past 7 Days:
31
Past 30 Days:
114
All Time:
2,107
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The WiFi card allows the laptop to connect to the Internet wirelessly. If you're experiencing network connection issues you may need to replace your WiFi card.
Tools
    1. Asus Z54C-JS31 WiFi Card Replacement, Battery: step 1, image 1 of 3 Asus Z54C-JS31 WiFi Card Replacement, Battery: step 1, image 2 of 3 Asus Z54C-JS31 WiFi Card Replacement, Battery: step 1, image 3 of 3
      • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
      • Slide the switch on the top right corner to the right.
      • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
      Ask FixBot
    1. Asus Z54C-JS31 WiFi Card Replacement, HDD/RAM Cover Panel: step 2, image 1 of 2 Asus Z54C-JS31 WiFi Card Replacement, HDD/RAM Cover Panel: step 2, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
      Ask FixBot
    2. Asus Z54C-JS31 WiFi Card Replacement: step 3, image 1 of 2 Asus Z54C-JS31 WiFi Card Replacement: step 3, image 2 of 2
      • Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
      Ask FixBot
    1. Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: step 4, image 1 of 3 Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: step 4, image 2 of 3 Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: step 4, image 3 of 3
      • Disconnect both the black and white coaxial connectors from the WiFi card by pulling up on the gold colored piece.
      Ask FixBot
    2. Asus Z54C-JS31 WiFi Card Replacement: step 5, image 1 of 3 Asus Z54C-JS31 WiFi Card Replacement: step 5, image 2 of 3 Asus Z54C-JS31 WiFi Card Replacement: step 5, image 3 of 3
      • Remove the 3mm screw from the top right corner of the WiFi card using a Phillips #0 screwdriver.
      • The WiFi card will pop up. Grasp it and pull it out of its slot.
      Ask FixBot
Mark DeSimone
801 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 31
Past 30 Days: 114
All Time: 2,107
