Asus Z54C-JS31 Optical Disc Drive Replacement
    1. Asus Z54C-JS31 Optical Disc Drive Replacement, Battery: step 1, image 1 of 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Battery: step 1, image 2 of 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Battery: step 1, image 3 of 3
      • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
      • Slide the switch on the top right corner to the right.
      • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
      Ask FixBot
    1. Asus Z54C-JS31 Optical Disc Drive Replacement, Keyboard: step 2, image 1 of 2 Asus Z54C-JS31 Optical Disc Drive Replacement, Keyboard: step 2, image 2 of 2
      • Turn the laptop to its normal position and open the display to show the keyboard.
      • Gently push back the five tabs holding the keyboard down using the plastic opening tool.
      Ask FixBot
    2. Asus Z54C-JS31 Optical Disc Drive Replacement: step 3, image 1 of 3 Asus Z54C-JS31 Optical Disc Drive Replacement: step 3, image 2 of 3 Asus Z54C-JS31 Optical Disc Drive Replacement: step 3, image 3 of 3
      • Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out.
      Ask FixBot
    1. Asus Z54C-JS31 Optical Disc Drive Replacement, Optical Disc Drive: step 4, image 1 of 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Optical Disc Drive: step 4, image 2 of 3 Asus Z54C-JS31 Optical Disc Drive Replacement, Optical Disc Drive: step 4, image 3 of 3
      • Remove the 3mm screw with a Phillips #000 screwdriver.
      • Slide out the optical disc drive by pulling it away from the laptop.
      Ask FixBot
Mark DeSimone
801 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 106
All Time: 418
