Asus Z54C-JS31 Hard Drive Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
89
All Time:
452
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The hard drive is important for storing the computer's data and may need to be replaced or upgraded to increase the amount of storage space.
Tools
    1. Asus Z54C-JS31 Hard Drive Replacement, Battery: step 1, image 1 of 3 Asus Z54C-JS31 Hard Drive Replacement, Battery: step 1, image 2 of 3 Asus Z54C-JS31 Hard Drive Replacement, Battery: step 1, image 3 of 3
      • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
      • Slide the switch on the top right corner to the right.
      • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
      Ask FixBot
    1. Asus Z54C-JS31 Hard Drive Replacement, HDD/RAM Cover Panel: step 2, image 1 of 2 Asus Z54C-JS31 Hard Drive Replacement, HDD/RAM Cover Panel: step 2, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
      Ask FixBot
    2. Asus Z54C-JS31 Hard Drive Replacement: step 3, image 1 of 2 Asus Z54C-JS31 Hard Drive Replacement: step 3, image 2 of 2
      • Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
      Ask FixBot
    1. Asus Z54C-JS31 Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Asus Z54C-JS31 Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
      • Remove the four 9mm screws holding the hard drive in place.
      Ask FixBot
    2. Asus Z54C-JS31 Hard Drive Replacement: step 5, image 1 of 3 Asus Z54C-JS31 Hard Drive Replacement: step 5, image 2 of 3 Asus Z54C-JS31 Hard Drive Replacement: step 5, image 3 of 3
      • Slide the hard drive to the left to disconnect it.
      • Then pull on the black tab to lift the hard drive out of the laptop.
      Ask FixBot
Mark DeSimone
801 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 89
All Time: 452
