Asus X55C HDD (Hard Disk Drive) Replacement
Views: 13K
View statistics:
Past 24 Hours:
6
Past 7 Days:
26
Past 30 Days:
129
All Time:
12,643
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
We will show you how to open the laptop and change / upgrade the HDD (hard disk drive).
Please SUBSCRIBE to my channel 惄
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Video Overview
    1. Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): step 1, image 1 of 3 Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): step 1, image 2 of 3 Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): step 1, image 3 of 3
      • Switch off the Laptop and remove the Battery.
      • Unscrew the two Philips screws and remove the HDD / RAM Cover.
      Ask FixBot
    2. Asus X55C HDD (Hard Disk Drive) Replacement: step 2, image 1 of 3 Asus X55C HDD (Hard Disk Drive) Replacement: step 2, image 2 of 3 Asus X55C HDD (Hard Disk Drive) Replacement: step 2, image 3 of 3
      • Remove three screws securing the hard drive caddy (hard drive assembly).
      • Slide the hard drive assembly to the left to disconnect it from the motherboard.
      Ask FixBot
    3. Asus X55C HDD (Hard Disk Drive) Replacement: step 3, image 1 of 1
      • Remove the two Philips screws and separate the HDD from the caddy case.
      • You can install 2.5" SATA HDD, 5400rpm / 7200rpm, 320GB / 500GB / 750GB /1TB.
      • After changing / upgrading the HDD you must install an operating system or clone & copy the information from the old HDD to the new one.
      • Did you do it successfully.
      • Please SUBSCRIBE to my channel 惄
      Ask FixBot
4 other people completed this guide.
ZFix
197,729 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
336 Members
8,282 Guides authored
1 Guide Comment
Were do you get the OS already installed on the drive. I have a Asus 550 with a 500 G and win 8.1. Looking to up grade to win 10 YES i have the GEO FORCE graphic card. Will I loose the use of the GEO FORCE. card. It has a i7 chip. And 6 g of line one cache would like to take to like 16 G… I would like to use the solid state hard drive. I understand it weathers bounces. Small slams and bangs better than the disc type. But I may not beable to afford this high a upgrade. Recommendations chrisdeiotte7@gmail.com
Chris Deiotte - Reply Share
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 129
All Time: 12,643
