Asus X555LA-SI305041 CD Drive Replacement
    1. Asus X555LA-SI305041 CD Drive Replacement, Keyboard Assembly: step 1, image 1 of 1
      • Remove the following Phillips #0 screws from the lower case:
      • Six 9 mm screws
      • Four 11 mm screws
      Ask FixBot
    2. Asus X555LA-SI305041 CD Drive Replacement: step 2, image 1 of 1
      • Use the plastic opening tool to separate the top cover from the laptop.
      • Start by prying on the front of the laptop.
      • Continue prying around the cover and end just under the screen to release the front cover.
      • Do not fully remove the top cover, it is attached by two ribbon cables that will be disconnected in the following steps.
      Ask FixBot
    3. Asus X555LA-SI305041 CD Drive Replacement: step 3, image 1 of 1
      • To release the ZIF latch, flip up the small white tab.
      • The connector may have a white base with a small grey rotating latch.
      • Pull the white ribbon cable out of the socket to disconnect it.
      • Very little force should be required to pull out the cable.
      Ask FixBot
    4. Asus X555LA-SI305041 CD Drive Replacement: step 4, image 1 of 1
      • To release the ZIF latch on the keyboard cable, flip the grey rotating tab up.
      • Gently pull the black and blue ribbon cable out of its connector.
      Ask FixBot
    5. Asus X555LA-SI305041 CD Drive Replacement: step 5, image 1 of 1
      • You can now fully remove the keyboard and front panel to gain access to the inside of the laptop.
      Ask FixBot
    1. Asus X555LA-SI305041 CD Drive Replacement, CD Drive: step 6, image 1 of 1
      • Using a #0 Phillips screw driver, remove the (5mm) black screw to the left of the CD Drive and to the right of the cooling fan.
      Ask FixBot
    2. Asus X555LA-SI305041 CD Drive Replacement: step 7, image 1 of 1
      • CD Drive should easily slide out.
      Ask FixBot
9 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 46
All Time: 8,854
