Asus X555LA-SI305041 Keyboard Assembly Replacement
    1. Asus X555LA-SI305041  Keyboard Assembly Replacement, Keyboard Assembly: step 1, image 1 of 1
      • Remove the following Phillips #0 screws from the lower case:
      • Six 9 mm screws
      • Four 11 mm screws
      Ask FixBot
    2. Asus X555LA-SI305041  Keyboard Assembly Replacement: step 2, image 1 of 1
      • Use the plastic opening tool to separate the top cover from the laptop.
      • Start by prying on the front of the laptop.
      • Continue prying around the cover and end just under the screen to release the front cover.
      • Do not fully remove the top cover, it is attached by two ribbon cables that will be disconnected in the following steps.
      Ask FixBot
    3. Asus X555LA-SI305041  Keyboard Assembly Replacement: step 3, image 1 of 1
      • To release the ZIF latch, flip up the small white tab.
      • The connector may have a white base with a small grey rotating latch.
      • Pull the white ribbon cable out of the socket to disconnect it.
      • Very little force should be required to pull out the cable.
      Ask FixBot
    4. Asus X555LA-SI305041  Keyboard Assembly Replacement: step 4, image 1 of 1
      • To release the ZIF latch on the keyboard cable, flip the grey rotating tab up.
      • Gently pull the black and blue ribbon cable out of its connector.
      Ask FixBot
    5. Asus X555LA-SI305041  Keyboard Assembly Replacement: step 5, image 1 of 1
      • You can now fully remove the keyboard and front panel to gain access to the inside of the laptop.
      Ask FixBot
13 other people completed this guide.
2 Guide Comments
Truly useless guide
vic_1199 - Reply Share
Could use some more steps on how to removed completely, including the touch-pad.
Can this be revised soon with more steps and pics? Please.
I need to replaced this keyboard because I have some non-working keys.
Frank P. - Reply Share
Past 24 Hours: 7
Past 7 Days: 42
Past 30 Days: 139
All Time: 11,089
