Asus X553MA-BPD07051 Battery Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
77
All Time:
3,485
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 25 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If you are having issues with your AsusX553MA-BPD07051 holding a charge, and you have identified that the issue is not the power cord adapter, the problem is most likely with the battery itself. Once you have identified that your battery does not function properly and needs to be replaced, this guide will allow for simple removal of the battery. Ensure that before working on your laptop, the laptop is completely turned off. For more troubleshooting assistance, check out this link. Before opening up the laptop, ensure that the device has been powered off to avoid being shocked.
Tools
Video Overview
    1. Asus X553MA-BPD07051 Battery Replacement, Battery: step 1, image 1 of 2 Asus X553MA-BPD07051 Battery Replacement, Battery: step 1, image 2 of 2
      • Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
      • Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
      Ask FixBot
    2. Asus X553MA-BPD07051 Battery Replacement: step 2, image 1 of 1
      • Lift the edges of the keyboard using the plastic iFixit opening tool and raise the keyboard slightly to see the inside of the laptop.
      • Do not lift the keyboard too high as the keyboard is connected to the motherboard by two ribbon connectors that must be detached.
      Ask FixBot
    3. Asus X553MA-BPD07051 Battery Replacement: step 3, image 1 of 2 Asus X553MA-BPD07051 Battery Replacement: step 3, image 2 of 2
      • Lift back the clip on the ribbon tape, and pull the tape out in order to remove the keyboard from the laptop.
      • Remove both pieces of the ribbon tape connecting the keyboard to the motherboard.
      Ask FixBot
    4. Asus X553MA-BPD07051 Battery Replacement: step 4, image 1 of 1
      • Remove the bundled cable connector attaching the battery to the motherboard with the plastic iFixit opening tool.
      • Make sure that you do not remove the entire connector by applying too much force. Only the white plastic connector should be removed from the metal part on the motherboard. Lift white part upwards to remove.
      Ask FixBot
    5. Asus X553MA-BPD07051 Battery Replacement: step 5, image 1 of 2 Asus X553MA-BPD07051 Battery Replacement: step 5, image 2 of 2
      • Use Phillips #0 screwdriver (PH0 bit) to remove the four 6.0 mm screws attaching the battery to the laptop.
      Ask FixBot
    6. Asus X553MA-BPD07051 Battery Replacement: step 6, image 1 of 2 Asus X553MA-BPD07051 Battery Replacement: step 6, image 2 of 2
      • Lift the battery up and remove it completely from the laptop.
      Ask FixBot
7 other people completed this guide.
Stephanie DeCarvalho
1,005 Reputation
5 Guides authored
2 Guide Comments
I used your guide when i repaired my mates X553. I found it quite easy. So thanks for the heads up on what to look out for :-)
gazza667 - Reply Share
Easy with the use of these clear instructions. Thanks and keep up the good work.
Marc Leclair - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 77
All Time: 3,485
