Up to 20% off select tools
Asus X551CA Power Button Replacement
Views: 14K
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
123
All Time:
13,779
Comments: 11
10 comments on steps, 1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The Asus X551CA power button allows the laptop to turn on and off. If it is broken, the laptop will not receive the signal to boot up.
    1. Asus X551CA Power Button Replacement, Keyboard Plate Cover: step 1, image 1 of 1
      • Power off and unplug your laptop before you begin.
      • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
      • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
      • Two 4.3 mm screws in the back corners
      • One 17.5 mm screw at the left edge near the optical drive
      • Three 4.3 mm screws in the front edge
      Ask FixBot
    2. Asus X551CA Power Button Replacement: step 2, image 1 of 1
      • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
      Ask FixBot
    3. Asus X551CA Power Button Replacement: step 3, image 1 of 1
      • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
      Ask FixBot
    4. Asus X551CA Power Button Replacement: step 4, image 1 of 3 Asus X551CA Power Button Replacement: step 4, image 2 of 3 Asus X551CA Power Button Replacement: step 4, image 3 of 3
      • Invert the laptop in order to gain access to the ribbons.
      • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
      Ask FixBot
    5. Asus X551CA Power Button Replacement: step 5, image 1 of 1
      • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
      Ask FixBot
    1. Asus X551CA Power Button Replacement, Power Button: step 6, image 1 of 1
      • Locate the power button in the corner of the keyboard plate cover.
      • Disconnect the ribbon from the small green board by flipping up the small white flap and pulling parallel to the green board's surface.
      Ask FixBot
    2. Asus X551CA Power Button Replacement: step 7, image 1 of 1
      • Remove the two 3.2 mm Phillips #0 screws on the power button using the Phillips #0 Screwdriver.
      Ask FixBot
    3. Asus X551CA Power Button Replacement: step 8, image 1 of 1
      • Remove the power button assembly by firmly grasping it from both sides and lifting it off of the keyboard plate cover.
      Ask FixBot
7 other people completed this guide.
Author
with
Josh
2,970 Reputation
12 Guides authored
Cal Poly, Team 7-22, Regan Spring 2014 Member of Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 Members
180 Guides authored
1 Guide Comment
I broke the middle ribbon! Do you know if that is replaceable? What part number would I order?
crwfd - Reply Share
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 123
All Time: 13,779
