Asus X551CA HD Web Camera
    1. Asus X551CA HD Web Camera, Keyboard Plate Cover: step 1, image 1 of 1
      • Power off and unplug your laptop before you begin.
      • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
      • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
      • Two 4.3 mm screws in the back corners
      • One 17.5 mm screw at the left edge near the optical drive
      • Three 4.3 mm screws in the front edge
      Ask FixBot
    2. Asus X551CA HD Web Camera: step 2, image 1 of 1
      • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
      Ask FixBot
    3. Asus X551CA HD Web Camera: step 3, image 1 of 1
      • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
      Ask FixBot
    4. Asus X551CA HD Web Camera: step 4, image 1 of 3 Asus X551CA HD Web Camera: step 4, image 2 of 3 Asus X551CA HD Web Camera: step 4, image 3 of 3
      • Invert the laptop in order to gain access to the ribbons.
      • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
      Ask FixBot
    5. Asus X551CA HD Web Camera: step 5, image 1 of 1
      • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
      Ask FixBot
    1. Asus X551CA HD Web Camera, Hard Drive: step 6, image 1 of 1
      • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
      Ask FixBot
    2. Asus X551CA HD Web Camera: step 7, image 1 of 1
      • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
      Ask FixBot
    3. Asus X551CA HD Web Camera: step 8, image 1 of 1
      • Once it is free, remove the hard drive from its internal cavity.
      Ask FixBot
    1. Asus X551CA HD Web Camera, Spacer: step 9, image 1 of 1
      • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
      Ask FixBot
    2. Asus X551CA HD Web Camera: step 10, image 1 of 1
      • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
      Ask FixBot
    1. Asus X551CA HD Web Camera, WiFi Card: step 11, image 1 of 1
      • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
      Ask FixBot
    2. Asus X551CA HD Web Camera: step 12, image 1 of 1
      • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
      Ask FixBot
    3. Asus X551CA HD Web Camera: step 13, image 1 of 1
      • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
      Ask FixBot
    1. Asus X551CA HD Web Camera, Battery: step 14, image 1 of 1
      • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
      Ask FixBot
    1. Asus X551CA HD Web Camera, Motherboard: step 15, image 1 of 1
      • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
      Ask FixBot
    2. Asus X551CA HD Web Camera: step 16, image 1 of 2 Asus X551CA HD Web Camera: step 16, image 2 of 2
      • Now, locate the two wires connected to the motherboard.
      Ask FixBot
    3. Asus X551CA HD Web Camera: step 17, image 1 of 2 Asus X551CA HD Web Camera: step 17, image 2 of 2
      • Remove the wires by easily pulling them parallel to the motherboard's surface.
      • The wires are very fragile. Be sure to pull carefully so that they do not break!
      Ask FixBot
    4. Asus X551CA HD Web Camera: step 18, image 1 of 2 Asus X551CA HD Web Camera: step 18, image 2 of 2
      • Remove the LCD display connection by gently pulling on the attached wire.
      • Gently lift any tape that may be holding the connection.
      Ask FixBot
    5. Asus X551CA HD Web Camera: step 19, image 1 of 1
      • Remove the motherboard from the case by gently lifting it upward.
      Ask FixBot
    1. Asus X551CA HD Web Camera, Front Display Bezel: step 20, image 1 of 1
      • Locate both of the hinges that connect the monitor to the bottom plate cover.
      Ask FixBot
    2. Asus X551CA HD Web Camera: step 21, image 1 of 2 Asus X551CA HD Web Camera: step 21, image 2 of 2
      • Use the Phillips #0 screwdriver to unscrew the two 4.8 mm Phillips #0 screws on the right hinge, and the one 4.8 mm Phillips #0 screw on the left hinge.
      Ask FixBot
    3. Asus X551CA HD Web Camera: step 22, image 1 of 1
      • Once the screws are removed, the monitor should easily lift away from the bottom plate cover
      Ask FixBot
    4. Asus X551CA HD Web Camera: step 23, image 1 of 1
      • Locate the two stickers that cover up the screws that hold the front bezel in place
      Ask FixBot
    5. Asus X551CA HD Web Camera: step 24, image 1 of 2 Asus X551CA HD Web Camera: step 24, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove these stickers.
      • The stickers can be difficult to grasp with the tweezers so do not be discouraged when trying to remove them!
      Ask FixBot
    6. Asus X551CA HD Web Camera: step 25, image 1 of 1
      • Once the stickers are removed, the two screws that hold the front bezel in place will be exposed.
      Ask FixBot
    7. Asus X551CA HD Web Camera: step 26, image 1 of 1
      • Use the Phillips #0 screwdriver to remove the two 4.8 mm Phillips #0 screws.
      Ask FixBot
    8. Asus X551CA HD Web Camera: step 27, image 1 of 2 Asus X551CA HD Web Camera: step 27, image 2 of 2
      • Once the screws are taken out, the front bezel is ready to be removed.
      • Insert the Plastic Opening Tool inbetween the front and back bezels and slide along the edges to pry open.
      • Gently use hands if necessary to separate the front bezel from the back.
      Ask FixBot
    9. Asus X551CA HD Web Camera: step 28, image 1 of 1
      • Once pried away from the back bezel, the front bezel will easily lift away from the LCD.
      Ask FixBot
    1. Asus X551CA HD Web Camera, LCD: step 29, image 1 of 1
      • Locate the twelve 3.2 mm Phillips #0 screws that hold the LCD in place.
      Ask FixBot
    2. Asus X551CA HD Web Camera: step 30, image 1 of 2 Asus X551CA HD Web Camera: step 30, image 2 of 2
      • Use the Philips #0 screwdriver to remove the twelve 3.2 mm Phillips #0 screws that hold the LCD in place.
      Ask FixBot
    3. Asus X551CA HD Web Camera: step 31, image 1 of 1
      • Once the screws are removed, lift up the LCD to expose the wire connecting the back bezel to the LCD.
      Ask FixBot
    4. Asus X551CA HD Web Camera: step 32, image 1 of 1
      • Gently unhook the wire from the back bezel to allow the LCD to be flipped over.
      Ask FixBot
    5. Asus X551CA HD Web Camera: step 33, image 1 of 1
      • Once flipped over, locate the ribbon that is connected to the back of the LCD.
      Ask FixBot
    6. Asus X551CA HD Web Camera: step 34, image 1 of 2 Asus X551CA HD Web Camera: step 34, image 2 of 2
      • Gently tug on the ribbon to remove it from the LCD.
      Ask FixBot
    7. Asus X551CA HD Web Camera: step 35, image 1 of 1
      • Now that the ribbon has been detached from the back, carefully remove the LCD.
      Ask FixBot
    1. Asus X551CA HD Web Camera, HD Web Camera: step 36, image 1 of 2 Asus X551CA HD Web Camera, HD Web Camera: step 36, image 2 of 2
      • Locate the camera on the back bezel.
      Ask FixBot
    2. Asus X551CA HD Web Camera: step 37, image 1 of 1
      • On the left hand side of the camera, there will be a wire. Gently pull on the wire to remove it.
      • Use caution when removing the wire. It is thin and easily damageable!
      Ask FixBot
    3. Asus X551CA HD Web Camera: step 38, image 1 of 1
      • Use both hands to carefully remove the camera out of its cavity.
      • The camera is held in by a piece of tape that will need to be removed.
      Ask FixBot
5 other people completed this guide.
Josh
2,970 Reputation
12 Guides authored
Cal Poly, Team 7-22, Regan Spring 2014 Member of Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 Members
180 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 105
All Time: 6,174
