Up to 20% off select tools
Asus X551CA Fan Replacement
Views: 6.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
96
All Time:
6,539
Comments: 22
21 comments on steps, 1 guide comment.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The fan in the Asus X551CA dissipates the heat generated by the laptop during use. It may fail after many hours of use.
    1. Asus X551CA Fan Replacement, Keyboard Plate Cover: step 1, image 1 of 1
      • Power off and unplug your laptop before you begin.
      • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
      • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
      • Two 4.3 mm screws in the back corners
      • One 17.5 mm screw at the left edge near the optical drive
      • Three 4.3 mm screws in the front edge
      Ask FixBot
    2. Asus X551CA Fan Replacement: step 2, image 1 of 1
      • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
      Ask FixBot
    3. Asus X551CA Fan Replacement: step 3, image 1 of 1
      • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
      Ask FixBot
    4. Asus X551CA Fan Replacement: step 4, image 1 of 3 Asus X551CA Fan Replacement: step 4, image 2 of 3 Asus X551CA Fan Replacement: step 4, image 3 of 3
      • Invert the laptop in order to gain access to the ribbons.
      • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
      Ask FixBot
    5. Asus X551CA Fan Replacement: step 5, image 1 of 1
      • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
      Ask FixBot
    1. Asus X551CA Fan Replacement, Hard Drive: step 6, image 1 of 1
      • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
      Ask FixBot
    2. Asus X551CA Fan Replacement: step 7, image 1 of 1
      • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
      Ask FixBot
    3. Asus X551CA Fan Replacement: step 8, image 1 of 1
      • Once it is free, remove the hard drive from its internal cavity.
      Ask FixBot
    1. Asus X551CA Fan Replacement, Spacer: step 9, image 1 of 1
      • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
      Ask FixBot
    2. Asus X551CA Fan Replacement: step 10, image 1 of 1
      • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
      Ask FixBot
    1. Asus X551CA Fan Replacement, WiFi Card: step 11, image 1 of 1
      • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
      Ask FixBot
    2. Asus X551CA Fan Replacement: step 12, image 1 of 1
      • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
      Ask FixBot
    3. Asus X551CA Fan Replacement: step 13, image 1 of 1
      • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
      Ask FixBot
    1. Asus X551CA Fan Replacement, Battery: step 14, image 1 of 1
      • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
      Ask FixBot
    1. Asus X551CA Fan Replacement, Motherboard: step 15, image 1 of 1
      • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
      Ask FixBot
    2. Asus X551CA Fan Replacement: step 16, image 1 of 2 Asus X551CA Fan Replacement: step 16, image 2 of 2
      • Now, locate the two wires connected to the motherboard.
      Ask FixBot
    3. Asus X551CA Fan Replacement: step 17, image 1 of 2 Asus X551CA Fan Replacement: step 17, image 2 of 2
      • Remove the wires by easily pulling them parallel to the motherboard's surface.
      • The wires are very fragile. Be sure to pull carefully so that they do not break!
      Ask FixBot
    4. Asus X551CA Fan Replacement: step 18, image 1 of 2 Asus X551CA Fan Replacement: step 18, image 2 of 2
      • Remove the LCD display connection by gently pulling on the attached wire.
      • Gently lift any tape that may be holding the connection.
      Ask FixBot
    5. Asus X551CA Fan Replacement: step 19, image 1 of 1
      • Remove the motherboard from the case by gently lifting it upward.
      Ask FixBot
    1. Asus X551CA Fan Replacement, Fan: step 20, image 1 of 1
      • Once the mother board is removed, locate the fan.
      Ask FixBot
    2. Asus X551CA Fan Replacement: step 21, image 1 of 1
      • Using the Phillips #0 screwdriver, remove the 5.5 mm Phillips #0 screw holding the fan in place.
      Ask FixBot
    3. Asus X551CA Fan Replacement: step 22, image 1 of 1
      • Lift the fan out of the laptop.
      Ask FixBot
8 other people completed this guide.
Author
with
Josh
2,970 Reputation
12 Guides authored
Cal Poly, Team 7-22, Regan Spring 2014 Member of Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 Members
180 Guides authored
1 Guide Comment
Upgrade the memory while you have the motherboard out. 8GB PC3L-12800 SODIMM
iceman - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 96
All Time: 6,539
