Up to 20% off select tools
Asus X5511M-RCLN03 Optical Drive Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
80
All Time:
1,426
Comments: 3
3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
This guide will instruct you on how to replace the optical drive in your Asus X5511M-RCLN03 laptop.
    1. Asus X5511M-RCLN03 Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
      • Position the laptop with the back cover facing upward.
      Ask FixBot
    2. Asus X5511M-RCLN03 Optical Drive Replacement: step 2, image 1 of 1
      • Remove all nine 4 mm screws from the back cover.
      Ask FixBot
    3. Asus X5511M-RCLN03 Optical Drive Replacement: step 3, image 1 of 1
      • Open the laptop with the keyboard facing upward."
      Ask FixBot
    4. Asus X5511M-RCLN03 Optical Drive Replacement: step 4, image 1 of 1
      • Pry up the keyboard using a plastic spudger.
      Ask FixBot
    5. Asus X5511M-RCLN03 Optical Drive Replacement: step 5, image 1 of 1
      • Remove the four, 4 mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    6. Asus X5511M-RCLN03 Optical Drive Replacement: step 6, image 1 of 1
      • Slide out the CD-ROM.
      Ask FixBot
Author
with
Andrew Hemphill
179 Reputation
1 Guide authored
3 Guide Comments
Peer Review:
Title: This should be changed, as this portion of the device is not a DVD player. It is a CD ROM drive.
Step 1: This step is unclear and seems unnecessary. It should be removed, or reworded to be more specific: "Position the laptop with the back cover facing upward."
-Step 2: This step should specify what screwdriver to use. Using markup in the image would also help the user with locating the screws.
Step 3: This step is also unclear and seems unnecessary. It should be removed, or reworded: "Re-position the laptop with the back cover facing downward."
Courtney Clark - Reply Share
-Step 4: This step is missing articles (i.e. pry up “the” keyboard using a spudger). Also, it should specific what spudger to use (plastic). The user should know not to use a metal spudger on their device.
Step 5: This step is missing an article (remove “the” screw).
Step 6: This step is unclear, and should refer to the “CD ROM drive”, not a DVD player. It should be reworded to be more clear. Example: “Slide out the CD ROM drive to remove it.”
Edit the title and link to the guide so that they say CD-ROM drive instead of DVD player.
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 80
All Time: 1,426
