Asus X540S panel Disassembly
      • Open the Optical Drive to allow removal of keyboard before powering down computer.
      Ask FixBot
    1. Asus X540S panel Disassembly: step 2, image 1 of 1
      • Remove the two 15mm Philips #1 screws.
      • Remove the two 12mm Philips #1 screws.
      • Remove the six 9mm Philips #1 screws.
      Ask FixBot
    2. Asus X540S panel Disassembly: step 3, image 1 of 3 Asus X540S panel Disassembly: step 3, image 2 of 3 Asus X540S panel Disassembly: step 3, image 3 of 3
      • Lift the side of the top.
      • Remove the keyboard cable.
      • Remove the trackpad cable.
      • Lift the release tabs on the keyboard/trackpad connectors
      Ask FixBot
16 other people completed this guide.
Padraic Hoselton
4,452 Reputation
12 Guides authored
Apple tech Member of Apple tech
Community
1 Member
144 Guides authored
4 Guide Comments
Feels like the panel is glued on mine. all screws are out, corners are loose but rest feels glued. anybody have advice? I dont have access to a heatgun
Non Gerrell - Reply Share
Well the first time I did it I had to give it a bit more pressure and loosen it up on all the sides. Because it should only be snapped in place. I don’t remember mine having glue the first time but I do remember I needed pry tools to get it off. I used some ifixit spudgers.
Padraic Hoselton - Reply Share
I used a plastic card (like credit card) to slide between the panels along the edge - it went smooth!
Alexey Sazonov - Reply Share
Le mien à subit un Court circuit comment faire pour le réparer
Merus Schadrack Djefly - Reply Share
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 157
All Time: 11,882
