Up to 20% off select tools
Asus X515 SSD Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
7
Past 7 Days:
73
Past 30 Days:
327
All Time:
2,703
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide I will be showing you how to replace the SSD in your ASUS X515.
    1. Asus X515 SSD Replacement, Flip over laptop: step 1, image 1 of 2 Asus X515 SSD Replacement, Flip over laptop: step 1, image 2 of 2
      • Power down the laptop and unplug all of the cables.
      • Flip over the laptop.
      Ask FixBot
    2. Asus X515 SSD Replacement, Take off bottom cover: step 2, image 1 of 2 Asus X515 SSD Replacement, Take off bottom cover: step 2, image 2 of 2
      • Remove the 10 phillips screws from the bottom of the case.
      • Using a prying tool pry the bottom of the case open.
      Ask FixBot
    3. Asus X515 SSD Replacement, Disconnect battery: step 3, image 1 of 3 Asus X515 SSD Replacement, Disconnect battery: step 3, image 2 of 3 Asus X515 SSD Replacement, Disconnect battery: step 3, image 3 of 3
      • Locate the battery and its connector.
      • Using your fingers or a prying tool pull up on the connector to disconnect it.
      Ask FixBot
    4. Asus X515 SSD Replacement, Remove the SSD: step 4, image 1 of 3 Asus X515 SSD Replacement, Remove the SSD: step 4, image 2 of 3 Asus X515 SSD Replacement, Remove the SSD: step 4, image 3 of 3
      • Locate the SSD
      • Peel the tape so that you can access the screw.
      • Remove the single screw.
      • The SSD will pop up and face outwards.
      • Pull the SSD outwards.
      Ask FixBot
Author
with
Jeremiah C.
847 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 73
Past 30 Days: 327
All Time: 2,703
