Asus X502C-RB01 Network Card Replacement
    1. Asus X502C-RB01 Network Card Replacement, Keyboard Panel: step 1, image 1 of 1
      • Turn off the laptop and flip it face down.
      • Using a Phillips #0 screwdriver, remove the seven 9mm screws circled in red.
      • With the same screwdriver, remove the four 5mm screws circled in orange.
      Ask FixBot
    2. Asus X502C-RB01 Network Card Replacement: step 2, image 1 of 1
      • Flip the laptop face up and open the lid.
      • Use the plastic opening tool to pry around the entire edge of the keyboard panel to loosen the panel from the base.
      • Be careful not to lift the panel just yet, as it is still connected to the motherboard.
      Ask FixBot
    3. Asus X502C-RB01 Network Card Replacement: step 3, image 1 of 2 Asus X502C-RB01 Network Card Replacement: step 3, image 2 of 2
      • Partially lift the panel up, revealing the two cables connected to the motherboard.
      Ask FixBot
    4. Asus X502C-RB01 Network Card Replacement: step 4, image 1 of 2 Asus X502C-RB01 Network Card Replacement: step 4, image 2 of 2
      • Disconnect the first ZIF cable by lifting the tab using the spuger tool or your fingernail and gently pull the cable out.
      • Disconnect the second ZIF cable by lifting the tab using your fingernail and gently pull the cable out. This one is more difficult to reach with the spudger.
      Ask FixBot
    5. Asus X502C-RB01 Network Card Replacement: step 5, image 1 of 1
      • Remove the keyboard panel completely and set it aside. The internal components of the laptop are now exposed.
      Ask FixBot
    1. Asus X502C-RB01 Network Card Replacement, Hard Drive: step 6, image 1 of 1
      • Locate the hard drive in the area highlighted in red.
      • This demonstration model does not have a mounting bracket around the hard drive.
      Ask FixBot
    2. Asus X502C-RB01 Network Card Replacement: step 7, image 1 of 1
      • Remove the four 5mm screws from the hard drive mounting bracket using the Phillips #0 screwdriver.
      Ask FixBot
    3. Asus X502C-RB01 Network Card Replacement: step 8, image 1 of 1
      • Slide the hard drive in the direction away from the connector and lift it up to remove it.
      Ask FixBot
    1. Asus X502C-RB01 Network Card Replacement, Motherboard: step 9, image 1 of 1
      • Unplug the battery from the laptop by lifting the connector up with the flat end of the spudger.
      • Unplug the two ZIF cables by lifting the tab using the spudger tool or your fingernail then pulling the cable out gently.
      Ask FixBot
    2. Asus X502C-RB01 Network Card Replacement: step 10, image 1 of 1
      • Unplug the bundled cable by pulling it away from the connector with a bit of force.
      • Unplug the display cable connector by lifting the tape and pulling it away from the connector.
      • Unplug the two antenna cables connected to the network interface card by prying it off with the flat end of the spudger.
      Ask FixBot
    3. Asus X502C-RB01 Network Card Replacement: step 11, image 1 of 2 Asus X502C-RB01 Network Card Replacement: step 11, image 2 of 2
      • Remove the four 5.5mm screws using the Phillips #0 screwdriver.
      Ask FixBot
    4. Asus X502C-RB01 Network Card Replacement: step 12, image 1 of 1
      • Gently lift the motherboard out of the casing.
      Ask FixBot
    1. Asus X502C-RB01 Network Card Replacement, Network Card: step 13, image 1 of 1
      • Flip over the motherboard so that the network card is now visible.
      Ask FixBot
    2. Asus X502C-RB01 Network Card Replacement: step 14, image 1 of 1
      • Remove the 5mm screw in the corner of the network card with a Phillips #0 screwdriver.
      Ask FixBot
    3. Asus X502C-RB01 Network Card Replacement: step 15, image 1 of 1
      • Lift the network card up and pull it out.
      • The network card may lift itself up to the angle pictured on its own.
      Ask FixBot
2 other people completed this guide.
Richard Hambrick
164 Reputation
1 Guide authored
UC Davis, Team 1-5, Rodger Winter 2017 Member of UC Davis, Team 1-5, Rodger Winter 2017
UCD-RODGER-W17S1G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 99
All Time: 944
