Asus X502C-RB01 Fan Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
88
All Time:
1,258
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If your laptop fan gets clogged with too much dust or is spinning too loud, you might want to clean or replace it. This guide will show you how to get to the fan and remove it to do so.
Tools
    1. Asus X502C-RB01 Fan Replacement, Keyboard Panel: step 1, image 1 of 1
      • Turn off the laptop and flip it face down.
      • Using a Phillips #0 screwdriver, remove the seven 9mm screws circled in red.
      • With the same screwdriver, remove the four 5mm screws circled in orange.
      Ask FixBot
    2. Asus X502C-RB01 Fan Replacement: step 2, image 1 of 1
      • Flip the laptop face up and open the lid.
      • Use the plastic opening tool to pry around the entire edge of the keyboard panel to loosen the panel from the base.
      • Be careful not to lift the panel just yet, as it is still connected to the motherboard.
      Ask FixBot
    3. Asus X502C-RB01 Fan Replacement: step 3, image 1 of 2 Asus X502C-RB01 Fan Replacement: step 3, image 2 of 2
      • Partially lift the panel up, revealing the two cables connected to the motherboard.
      Ask FixBot
    4. Asus X502C-RB01 Fan Replacement: step 4, image 1 of 2 Asus X502C-RB01 Fan Replacement: step 4, image 2 of 2
      • Disconnect the first ZIF cable by lifting the tab using the spuger tool or your fingernail and gently pull the cable out.
      • Disconnect the second ZIF cable by lifting the tab using your fingernail and gently pull the cable out. This one is more difficult to reach with the spudger.
      Ask FixBot
    5. Asus X502C-RB01 Fan Replacement: step 5, image 1 of 1
      • Remove the keyboard panel completely and set it aside. The internal components of the laptop are now exposed.
      Ask FixBot
    1. Asus X502C-RB01 Fan Replacement, Hard Drive: step 6, image 1 of 1
      • Locate the hard drive in the area highlighted in red.
      • This demonstration model does not have a mounting bracket around the hard drive.
      Ask FixBot
    2. Asus X502C-RB01 Fan Replacement: step 7, image 1 of 1
      • Remove the four 5mm screws from the hard drive mounting bracket using the Phillips #0 screwdriver.
      Ask FixBot
    3. Asus X502C-RB01 Fan Replacement: step 8, image 1 of 1
      • Slide the hard drive in the direction away from the connector and lift it up to remove it.
      Ask FixBot
    1. Asus X502C-RB01 Fan Replacement, Motherboard: step 9, image 1 of 1
      • Unplug the battery from the laptop by lifting the connector up with the flat end of the spudger.
      • Unplug the two ZIF cables by lifting the tab using the spudger tool or your fingernail then pulling the cable out gently.
      Ask FixBot
    2. Asus X502C-RB01 Fan Replacement: step 10, image 1 of 1
      • Unplug the bundled cable by pulling it away from the connector with a bit of force.
      • Unplug the display cable connector by lifting the tape and pulling it away from the connector.
      • Unplug the two antenna cables connected to the network interface card by prying it off with the flat end of the spudger.
      Ask FixBot
    3. Asus X502C-RB01 Fan Replacement: step 11, image 1 of 2 Asus X502C-RB01 Fan Replacement: step 11, image 2 of 2
      • Remove the four 5.5mm screws using the Phillips #0 screwdriver.
      Ask FixBot
    4. Asus X502C-RB01 Fan Replacement: step 12, image 1 of 1
      • Gently lift the motherboard out of the casing.
      Ask FixBot
    1. Asus X502C-RB01 Fan Replacement, Fan: step 13, image 1 of 1
      • Flip the motherboard over so the fan is right side up.
      Ask FixBot
    2. Asus X502C-RB01 Fan Replacement: step 14, image 1 of 1
      • Disconnect the fan from the motherboard by pulling the power cable connector.
      Ask FixBot
    3. Asus X502C-RB01 Fan Replacement: step 15, image 1 of 1
      • Remove the two 5.5mm screws using a Phillips #0 head screwdriver.
      Ask FixBot
    4. Asus X502C-RB01 Fan Replacement: step 16, image 1 of 1
      • Detach the tape that connects the fan to the heatsink.
      Ask FixBot
    5. Asus X502C-RB01 Fan Replacement: step 17, image 1 of 1
      • Lift the fan off to remove it from the motherboard.
      Ask FixBot
2 other people completed this guide.
Frances Tan
143 Reputation
1 Guide authored
UC Davis, Team 1-5, Rodger Winter 2017 Member of UC Davis, Team 1-5, Rodger Winter 2017
UCD-RODGER-W17S1G5
4 Members
72 Guides authored
1 Guide Comment
Great guide. Re: STEP 11 - my Asus notebook had 5 screws securing the mb.
u1oo - Reply Share
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 88
All Time: 1,258
