Asus X501A-RH31 Touch Pad Replacement
    1. Asus X501A-RH31 Touch Pad Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over so that the back is facing upwards.
      Ask FixBot
    2. Asus X501A-RH31 Touch Pad Replacement: step 2, image 1 of 1
      • To unlock the left tab, make sure the tab on the left has red showing.
      Ask FixBot
    3. Asus X501A-RH31 Touch Pad Replacement: step 3, image 1 of 2 Asus X501A-RH31 Touch Pad Replacement: step 3, image 2 of 2
      • To unlock the right tab, push the right slider to the left with one hand.
      • Push the battery out with the other hand.
      Ask FixBot
    1. Asus X501A-RH31 Touch Pad Replacement, Keyboard: step 4, image 1 of 2 Asus X501A-RH31 Touch Pad Replacement, Keyboard: step 4, image 2 of 2
      • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
      • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
      Ask FixBot
    2. Asus X501A-RH31 Touch Pad Replacement: step 5, image 1 of 1
      • Turn the laptop over and open the top so the keyboard is facing you.
      Ask FixBot
    3. Asus X501A-RH31 Touch Pad Replacement: step 6, image 1 of 2 Asus X501A-RH31 Touch Pad Replacement: step 6, image 2 of 2
      • Pry off the keyboard cover on the edge using the plastic opening tool.
      • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
      • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
      Ask FixBot
    4. Asus X501A-RH31 Touch Pad Replacement: step 7, image 1 of 1
      • Slowly lift the keyboard upward, but do not remove completely.
      • Remove the two data cables that attach the keyboard to the motherboard.
      Ask FixBot
    5. Asus X501A-RH31 Touch Pad Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to pull the white plastic piece up that is attached to the data cable.
      • Repeat this process for the big black cable as well.
      • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
      Ask FixBot
    1. Asus X501A-RH31 Touch Pad Replacement, Touch Pad: step 9, image 1 of 2 Asus X501A-RH31 Touch Pad Replacement, Touch Pad: step 9, image 2 of 2
      • Flip the keyboard over so the side without the keys is facing you.
      • Using the Phillips #00 screwdriver, unscrew the three screws.
      • The three screws are 2mm in length, 6.5mm in diameter.
      Ask FixBot
    2. Asus X501A-RH31 Touch Pad Replacement: step 10, image 1 of 2 Asus X501A-RH31 Touch Pad Replacement: step 10, image 2 of 2
      Buy
      • Detach the white data cable on the back of the touch pad.
      • Use tweezers to pull the white plastic piece up that is holding in the cable.
      Ask FixBot
    3. Asus X501A-RH31 Touch Pad Replacement: step 11, image 1 of 1
      • Peel the tan tape that holds the touch pad to the back of the keyboard.
      • Slide the touch pad up and out of the metal plate located near the bottom on the touch pad and keyboard.
      Ask FixBot
Christopher
371 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 29
All Time: 884
