Up to 20% off select tools
Asus X501A-RH31 Keyboard Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
8
Past 7 Days:
22
Past 30 Days:
96
All Time:
1,888
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will demonstrate how to properly replace the Asus X501A-RH31 keyboard. Please note that there are parts connecting the keyboard to the motherboard that could easily break if the steps are not executed correctly.
    1. Asus X501A-RH31 Keyboard  Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over so that the back is facing upwards.
      Ask FixBot
    2. Asus X501A-RH31 Keyboard  Replacement: step 2, image 1 of 1
      • To unlock the left tab, make sure the tab on the left has red showing.
      Ask FixBot
    3. Asus X501A-RH31 Keyboard  Replacement: step 3, image 1 of 2 Asus X501A-RH31 Keyboard  Replacement: step 3, image 2 of 2
      • To unlock the right tab, push the right slider to the left with one hand.
      • Push the battery out with the other hand.
      Ask FixBot
    1. Asus X501A-RH31 Keyboard  Replacement, Keyboard: step 4, image 1 of 2 Asus X501A-RH31 Keyboard  Replacement, Keyboard: step 4, image 2 of 2
      • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
      • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
      Ask FixBot
    2. Asus X501A-RH31 Keyboard  Replacement: step 5, image 1 of 1
      • Turn the laptop over and open the top so the keyboard is facing you.
      Ask FixBot
    3. Asus X501A-RH31 Keyboard  Replacement: step 6, image 1 of 2 Asus X501A-RH31 Keyboard  Replacement: step 6, image 2 of 2
      • Pry off the keyboard cover on the edge using the plastic opening tool.
      • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
      • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
      Ask FixBot
    4. Asus X501A-RH31 Keyboard  Replacement: step 7, image 1 of 1
      • Slowly lift the keyboard upward, but do not remove completely.
      • Remove the two data cables that attach the keyboard to the motherboard.
      Ask FixBot
    5. Asus X501A-RH31 Keyboard  Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to pull the white plastic piece up that is attached to the data cable.
      • Repeat this process for the big black cable as well.
      • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
      Ask FixBot
Author
with
Romana Hruby
596 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 22
Past 30 Days: 96
All Time: 1,888
