Up to 20% off select tools
Asus X401A Processor Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
111
All Time:
2,716
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to take apart your laptop in order to get to the processor, fan, graphics card, and many other important components. Through the steps listed below, you will be able to identify and replace your laptop's processor!
    1. Asus X401A Processor Replacement, Processor: step 1, image 1 of 2 Asus X401A Processor Replacement, Processor: step 1, image 2 of 2
      • Turn your laptop off and unplug it from its charger prior to the repair to avoid electric shock.
      • Turn your laptop over, and press on the latches to remove the battery.
      Ask FixBot
    2. Asus X401A Processor Replacement: step 2, image 1 of 3 Asus X401A Processor Replacement: step 2, image 2 of 3 Asus X401A Processor Replacement: step 2, image 3 of 3
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Unscrew the ten screws with a Phillips Head #1 screwdriver.
      • Eight screws are 3mm.
      • Two screws are 4mm.
      • Place the screws on a magnetic mat.
      Ask FixBot
    3. Asus X401A Processor Replacement: step 3, image 1 of 3 Asus X401A Processor Replacement: step 3, image 2 of 3 Asus X401A Processor Replacement: step 3, image 3 of 3
      • Separate the keyboard from the back of the laptop with a plastic opening tool.
      • Do not completely separate the two pieces as there are ribbon cables that need to be disconnected.
      • When reassembling, you will hear snapping noises as the pieces connect together.
      Ask FixBot
    4. Asus X401A Processor Replacement: step 4, image 1 of 3 Asus X401A Processor Replacement: step 4, image 2 of 3 Asus X401A Processor Replacement: step 4, image 3 of 3
      • Use a spudger to lift ZIF tabs up to disconnect the black and the white ribbon cable.
      Ask FixBot
    5. Asus X401A Processor Replacement: step 5, image 1 of 1
      • Unscrew the ten 3mm screws with a Phillips Head #1 screwdriver,
      Ask FixBot
    6. Asus X401A Processor Replacement: step 6, image 1 of 1
      • Use a spudger to lift the ZIF connector up to release the ribbon cable.
      Ask FixBot
    7. Asus X401A Processor Replacement: step 7, image 1 of 2 Asus X401A Processor Replacement: step 7, image 2 of 2
      • Lift the connection between the screen and motherboard with a plastic spudger.
      • Remove the yellow and the clear tape.
      Ask FixBot
    8. Asus X401A Processor Replacement: step 8, image 1 of 1
      • Disconnect the wire connecting the speakers.
      Ask FixBot
    9. Asus X401A Processor Replacement: step 9, image 1 of 3 Asus X401A Processor Replacement: step 9, image 2 of 3 Asus X401A Processor Replacement: step 9, image 3 of 3
      • Lift the motherboard from the frame with a plastic spudger.
      • Set the frame of the laptop aside, and turn the motherboard over.
      Ask FixBot
    10. Asus X401A Processor Replacement: step 10, image 1 of 2 Asus X401A Processor Replacement: step 10, image 2 of 2
      • Unscrew the four screws with a Phillips Head #1 screwdriver to disconnect the fan from the processor.
      Ask FixBot
    11. Asus X401A Processor Replacement: step 11, image 1 of 2 Asus X401A Processor Replacement: step 11, image 2 of 2
      • Disconnect the cable connecting the fan to the motherboard.
      • Lift the fan part from the processor.
      Ask FixBot
    12. Asus X401A Processor Replacement: step 12, image 1 of 3 Asus X401A Processor Replacement: step 12, image 2 of 3 Asus X401A Processor Replacement: step 12, image 3 of 3
      • Unscrew the screw holding the processor to the motherboard with a flathead screwdriver.
      • Lift the processor up away from the socket.
      Ask FixBot
2 other people completed this guide.
Author
with
Tyler Stiles
152 Reputation
1 Guide authored
Ohio State, Team 1-4, Wilder Spring 2017 Member of Ohio State, Team 1-4, Wilder Spring 2017
OSU-WILDER-S17S1G4
4 Members
60 Guides authored
1 Guide Comment
Hi
What is the highest CPU I can put on it?
Does Asus X401A support i5-2450M?
mmaksat1988 - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 111
All Time: 2,716
