Asus X202E-UH31T Battery Replacement
    1. Asus X202E-UH31T Battery Replacement, Battery: step 1, image 1 of 1
      • Remove the nine 1.2mm Phillips screws that secure the lower case.
      Ask FixBot
    2. Asus X202E-UH31T Battery Replacement: step 2, image 1 of 1
      • Use a plastic opening tool to open the components of the laptop. In order to do this, insert the plastic opening tool in between the two covers then pry open.
      Ask FixBot
    3. Asus X202E-UH31T Battery Replacement: step 3, image 1 of 1
      • Remove the seven 1.2mm Phillips screws that secure the battery.
      Ask FixBot
    4. Asus X202E-UH31T Battery Replacement: step 4, image 1 of 1
      • Use an opening tool to the plastic opening tool to disconnect the battery from its motherboard socket.
      • Lift the battery up and out of the chassis.
      Ask FixBot
    5. Asus X202E-UH31T Battery Replacement: step 5, image 1 of 1
      • After replacing the battery, attach the wire ribbon to the motherboard and screw the designated screws back into the battery to secure it
      Ask FixBot
To reassemble your device, follow these steps in reverse order.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 40
All Time: 1,869
