Up to 20% off select tools
Asus X200MA Trackpad Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
87
All Time:
2,772
Comments: 4
4 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the trackpad on your Asus X200MA.
    1. Asus X200MA Trackpad Replacement, Back Panel: step 1, image 1 of 1
      • Remove the following six screws:
      • Six 4 mm screws using a Phillips #0 screwdriver.
      • Remove the following one screw:
      • One 14 mm screw using a Phillips #0 screwdriver.
      • The 14mm screw goes in the center.
      Ask FixBot
    2. Asus X200MA Trackpad Replacement: step 2, image 1 of 1
      • Take two rubber caps off the back side of the laptop.
      • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
      Ask FixBot
    3. Asus X200MA Trackpad Replacement: step 3, image 1 of 1
      • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
      Ask FixBot
    1. Asus X200MA Trackpad Replacement, Trackpad: step 4, image 1 of 2 Asus X200MA Trackpad Replacement, Trackpad: step 4, image 2 of 2
      • Use the spudger to lift up and remove the black plastic covering.
      Ask FixBot
    2. Asus X200MA Trackpad Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Remove thinner white strip by first flipping up black piece at the top of the strip with the tweezers and then pulling it out.
      Ask FixBot
    3. Asus X200MA Trackpad Replacement, Mouse: step 6, image 1 of 1
      • Remove wider blue strip with tweezers.
      Ask FixBot
    4. Asus X200MA Trackpad Replacement: step 7, image 1 of 1
      • Remove the following eight screws:
      • Eight 3 mm screws using Phillips #0 screwdriver.
      Ask FixBot
    5. Asus X200MA Trackpad Replacement: step 8, image 1 of 1
      • Remove the following two screws after lifting metal plate off:
      • Two 2 mmm screws using a Phillips #0 screwdriver.
      Ask FixBot
    6. Asus X200MA Trackpad Replacement: step 9, image 1 of 2 Asus X200MA Trackpad Replacement: step 9, image 2 of 2
      • Use metal spudger to get in between mouse pad and keyboard and lift off.
      Ask FixBot
Author
with
Vanessa Garcia
1,817 Reputation
6 Guides authored
Cal Poly, Team 21-24, Maness Winter 2015 Member of Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 87
All Time: 2,772
