Asus X200MA Speaker Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
66
All Time:
944
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide provides step-by-step instructions on the replacement of the speaker of ASUS X200MA. This guide can be used to replace broken speakers or upgrade on this laptop. Use caution when removing the wires and removing the glued speakers with a spudger, as these are delicate processes.
Tools
    1. Asus X200MA Speaker Replacement, Back Panel: step 1, image 1 of 1
      • Remove the following six screws:
      • Six 4 mm screws using a Phillips #0 screwdriver.
      • Remove the following one screw:
      • One 14 mm screw using a Phillips #0 screwdriver.
      • The 14mm screw goes in the center.
      Ask FixBot
    2. Asus X200MA Speaker Replacement: step 2, image 1 of 1
      • Take two rubber caps off the back side of the laptop.
      • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
      Ask FixBot
    3. Asus X200MA Speaker Replacement: step 3, image 1 of 1
      • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
      Ask FixBot
    1. Asus X200MA Speaker Replacement, Speaker: step 4, image 1 of 1
      • Disconnect the gold cap that connects to a black wire using the metal spudger.
      Ask FixBot
    2. Asus X200MA Speaker Replacement: step 5, image 1 of 1
      • Remove the plastic component from the clip by gently pulling it back.
      Ask FixBot
    3. Asus X200MA Speaker Replacement: step 6, image 1 of 2 Asus X200MA Speaker Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Use the tweezers to free the speaker from the plastic clips.
      • Use a finger to lift the speaker and break the bond between the adhesive on the base plate and the speaker.
      Ask FixBot
    4. Asus X200MA Speaker Replacement: step 7, image 1 of 3 Asus X200MA Speaker Replacement: step 7, image 2 of 3 Asus X200MA Speaker Replacement: step 7, image 3 of 3
      • Use the tweezers to carefully lift the wires from the plastic clips.
      Ask FixBot
    5. Asus X200MA Speaker Replacement: step 8, image 1 of 2 Asus X200MA Speaker Replacement: step 8, image 2 of 2
      • Use the metal tweezers to free the speaker from the plastic clips.
      • Use the metal spudger to break the bond between the base plate adhesive and the speaker.
      • Lift the speakers and remove them from the base plate.
      Ask FixBot
To reassemble your device, follow these instructions in reverse [#|order].
Alli Krininger
391 Reputation
3 Guides authored
IUPUI, Team S2-G4, Stella Fall 2019 Member of IUPUI, Team S2-G4, Stella Fall 2019
IUPUI-STELLA-F19S2G4
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 66
All Time: 944
