Asus X200MA Hard Drive Replacement
    1. Asus X200MA Hard Drive Replacement, Back Panel: step 1, image 1 of 1
      • Remove the following six screws:
      • Six 4 mm screws using a Phillips #0 screwdriver.
      • Remove the following one screw:
      • One 14 mm screw using a Phillips #0 screwdriver.
      • The 14mm screw goes in the center.
      Ask FixBot
    2. Asus X200MA Hard Drive Replacement: step 2, image 1 of 1
      • Take two rubber caps off the back side of the laptop.
      • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
      Ask FixBot
    3. Asus X200MA Hard Drive Replacement: step 3, image 1 of 1
      • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
      Ask FixBot
    1. Asus X200MA Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
      • The 14 mm screw goes in the center.
      Ask FixBot
    2. Asus X200MA Hard Drive Replacement: step 5, image 1 of 1
      • Remove the following four screws:
      • Four 4 mm Phillips #0 using a phillips screwdriver.
      Ask FixBot
    3. Asus X200MA Hard Drive Replacement: step 6, image 1 of 1
      • Slide out the hard drive
      Ask FixBot
3 other people completed this guide.
Vanessa Garcia
1,817 Reputation
6 Guides authored
Cal Poly, Team 21-24, Maness Winter 2015 Member of Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Members
72 Guides authored
2 Guide Comments
You FORGOT TO MENTION that one must remove the 2 Rubber feet to get at 2 more screws :-(((((((
Matthew Miller - Reply Share
Very poor!!! If you follow this instruction, you will destroy your Laptop. I did nearly destroying it. You did not show the 2 screws under the rubbers.
Minus 1000 points!!!
luft_ha - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 121
All Time: 10,197
