Up to 20% off select tools
Asus X200CA Keyboard Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
85
All Time:
1,750
Comments: 4
4 comments on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Asus X200CA Keyboard Replacement, Keyboard: step 1, image 1 of 2 Asus X200CA Keyboard Replacement, Keyboard: step 1, image 2 of 2
      • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
      • Remove the black 14.5mm screw from the center of the bottom cover.
      Ask FixBot
    2. Asus X200CA Keyboard Replacement: step 2, image 1 of 1
      • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
      Ask FixBot
    3. Asus X200CA Keyboard Replacement: step 3, image 1 of 1
      • Pull apart the keyboard and the bottom cover using your hands.
      • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
      Ask FixBot
5 other people completed this guide.
Author
with
Jacqueline Collier
1,119 Reputation
5 Guides authored
USF Tampa, Team S1-G2, Leahy Fall 2017 Member of USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 85
All Time: 1,750
